Things are working! Here’s what I did:
Deleted app
Installed app
entered “Interface Password” clicked “Set” button
entered “Installer Code” clicked “Set” button
clicked “Detect” button for IP Address
detected ok.
Clicked read panel
Several messages up top, worked ok, Panel time (incorrect) appeared next to “Sync Time” button.
“Backing up” message appeared up top.
“Backup Success” message appeared up top then went away.
Assigned to room: Basement, “Save Changes” Success
Clicked “Sync Time” button, correct day/time/date appeared.
And the alarm shows up in Devices!!
For the next part, please forgive me if I’m posting in the wrong place - as it may not have anything to do with the plugin/app.
Now, my devices seem… not what I expected.
When I first moved into the house (last April) I had: Front Door sensor, Living Room Motion sensor, Basement door Sensor, Basement Motion Sensor, Back Hall Motion Sensor. No instructions, no connection to an alarm company, no codes, just the panel and my curious brain.
I found a manual online, and helpful forums, and got the installer code and made my master code and PIN codes to control it. I was then able to arm/disarm, and successfully set it off by accident with the front door twice!
A few months ago I removed the wires (bypassed with resistors) in the box from the Living Room Motion sensor, and the Back Hall Motion Sensor, as I didn’t want to use them.
From my keypads by the front door and upstairs, I am able to arm/disarm.
My Vera dashboard shows:
Zone #04 - picture of motion sensor
Zone #03 - picture of motion sensor
Zone #02 - picture of motion sensor
Zone #01 - picture of door sensor
They all have “bypassed” with the slide button greyed out. When I clicked one of the slide buttons to see what would happen (don’t judge!) I got a message up top: “Can’t remove zone bypass for a single zone. Perform a partition disarm to remove all zone bypasses.”
When I click “Away” to arm in Vera, I get a message: “Cannot arm/disarm without PIN code.”
I found where to add my PIN, did so.
Clicked “Away” and heard the beeps and my panel armed, and all 4 zones show “armed” in red.
I clicked “Disarm” and heard the beep and “disarm” is green… but all 4 zones still are red and say “Armed”.
So, let me TL;DR for my questions:
Why does Vera show 3 motion detectors for zones 1,2,3, and a door/window for 4, when it should show (as far as I know) 2 doors and 1 motion detector?
How DO I find out what I have?
Does a red “Armed” simply mean that the zone is not bypassed?
How do I get a zone back after clicking “bypass” and having it work and that zone disappeared? (again, don’t judge, I’m clicky!)
