Program Logic Timer Switch (PLTS) is a flexible timed switch that may be controlled using buttons on the User Interface (UI) and/or Condition expressions like those used in PLEG.
Use PLTS when you want an accurate timed output with relatively simple logic or if you want to monitor and control the timer from the UI. If you need multiple outputs or complex logic, PLEG may offer a better solution.
PLTS Basics is intended to provide newcomers with an explanation of how PLTS works and how to use its many features. Each feature is described in detail with examples of how it may be used. The guide is in the form of a pdf document with bookmarks to help with navigation.
Edit: 29/01/2014 15:18 Updated to reflect changes in PLTS V5.7
Edit: 07/03/2014 14:00 Updated to reflect changes in PLTS V6.2
