I was just looking thru my hard drive trying to figure out what is taking up space and I stumbled on 6GB worth of Plex DLNA Server Neptune logs in %LOCALAPPDATA%\Plex Media Server\Logs. I wondered what could Plex log that much and discovered it all had to do with alarm. So I search for plex and vera and here I am.
Following is in there over and over:
[code]
2
0
<!-- The High Level State of the Partition, representing whether it’s Armed or Disarmed.
Partition implementations are only required to implement the "Armed" and "Disarmed" states
since not every Panel provides the ability to "see" the other statuses and reflect
them to the UPnP consumer.
Disarmed - The Partition is in an un-armed state, and ready to be Armed.
Armed - The Partition is currently armed, or in an "away" state.
<stateVariable sendEvents="yes">
<name>ArmMode</name>
<dataType>string</dataType>
<shortCode>armmode</shortCode>
<defaultValue>Disarmed</defaultValue>
<allowedValueList>
<allowedValue>Disarmed</allowedValue>
<allowedValue>Armed</allowedValue>
</allowedValueList>
</stateVariable>
<!-- The Detailed state of the Partition, representing whether it's Armed, Disarmed or one
of the common intermediary states.
Partition implementations are required to implement the "Armed" and "Disarmed" states,
corresponding to the State variable above. Not every Panel provides the required API
to "see" the other statuses and reflect them to the UPnP consumer.
Note that some implementations may consider the "ExitDelay" state to be "Armed"
whilst others may consider them to be "Disarmed". No association between DetailedArmMode
and State variables should be assumed by UPnP clients, due to this potential difference.
Some of the states may be transitional, and no guarantees are provided that the Panel
will complete any subsequent transition to a corresponding permanent state.
UPnP clients should make no assumptions about the "next state" from what is
immediately presented, since this may be Vendor and/or Implementation specific.
Some of the states, like Night/NightInstant and Vacation, are included for specific Panel
vendors like the Elk and may not be present on other Panels. Control Point authors should
be prepared to display these DetailedArmMode using an CP-specific visualization (an Icon,
Translated Text and so-on)
Disarmed - The Partition is disarmed.
ArmedInstant - The Partition is currently armed, or in an "away" state, Entry triggers Alarm immediately.
Stay - The Partition is in an "at-home" state, delays are permitted on Entry doors.
StayInstant - The Partition is in an "at-home" state, Entry doors trigger Alarm immediately.
Night - The Partition is in an "at-home, at-night" state, delays are permitted on Entry doors.
NightInstant - The Partition is in an "at-home, at-night" state, Entry doors trigger Alarm immediately.
Force - The Partition is in an "away" state, but one or more Zones are open.
Ready - The Partition is in an un-armed state, and ready to be Armed.
Vacation - The Partition is currently armed, or in an "away" state.
NotReady - The Partition is in an un-armed state, but one or more Zones are open.
FailedToArm - The Partition is in an un-armed state, and an arming attempt just failed.
EntryDelay - The Partition is currently moving towards the Disarmed state.
ExitDelay - The Partition is currently moving towards the Armed state.
<name>DetailedArmMode</name>
<shortCode>detailedarmmode</shortCode>
<defaultValue>Ready</defaultValue>
<allowedValueList>
<allowedValue>ArmedInstant</allowedValue>
<allowedValue>Stay</allowedValue>
<allowedValue>StayInstant</allowedValue>
<allowedValue>Night</allowedValue>
<allowedValue>NightInstant</allowedValue>
<allowedValue>Force</allowedValue>
<allowedValue>Ready</allowedValue>
<allowedValue>Vacation</allowedValue>
<allowedValue>NotReady</allowedValue>
<allowedValue>FailedToArm</allowedValue>
<allowedValue>EntryDelay</allowedValue>
<allowedValue>ExitDelay</allowedValue>
</allowedValueList>
</stateVariable>
<!-- An indicator of whether the Partition is in Alarm state or not.
Partition implementations are only required to implement the "None" and "Active"
states.
Many alarm systems will "automatically" clear a Alarm state after some, often legally
mandated, period of time. If this happens, the Partition should move to the "None"
state, but also has the option of setting the "AlarmMemory" state.
None - The Partition is not currently in Alarm, and no prior record of Alarm.
Active - The Partition is currently showing as an Alarm actively going off.
<name>Alarm</name>
<shortCode>alarm</shortCode>
<defaultValue>None</defaultValue>
<allowedValueList>
<allowedValue>None</allowedValue>
<allowedValue>Active</allowedValue>
</allowedValueList>
</stateVariable>
<!-- An indicator of whether the Partition has Chime mode enabled.
Some Alarm Systems (DSC, Paradox, GE Caddx) can run in a mode where each Zone
that's opened will trigger a Chime, or Bell, to ring for a short period of
time. This setting is independant of any Armed or Disarmed state of the
Partition.
If the Panel supports intraspection of this property, then the value should
be brought forward. Some panels (Paradox) support the setting, but don't
support the intraspection of the setting. In these cases, the Partition
implementation must return "false" for this attribute.
true - The Partition is in Chime mode, and will ring a Bell when Zones are opened.
false - Chimes are disabled. No chime/sound will occur when a Zone is opened.
<name>ChimeEnabled</name>
<dataType>boolean</dataType>
<shortCode>chimeenabled</shortCode>
<defaultValue>false</defaultValue>
</stateVariable>
<!-- An indicator of whether the Partition has previously been in an Alarm state.
Each Panel, has a Panel-specific mechanism through which it will transition/clear
it's "AlarmMemory" state.
true - A prior Alarm state occurred, but it has since cleared
false - No prior Alarm state is known, or the Prior Alarm condition has been cleared.
<stateVariable sendEvents="yes" allowRepeats="yes">
<name>AlarmMemory</name>
<shortCode>alarmmemory</shortCode>
</stateVariable>
<!-- An indicator of when the Partition last entered "Active" state.
Not all Alarm systems support the information necessary to know that a Alarm has been
"reset" distinctly from it being "cleared" by some automated means.
If any implementation returns "Memory", for Alarm, then it must supply a non-Zero
value for this StateVariable.
0 - Default value if "Memory" is not supported, or if no prior record of Alarm.
TODO: represented as seconds past epoch???
<name>LastAlarmActive</name>
<dataType>ui4</dataType>
<shortCode>lastalarmactive</shortCode>
<defaultValue>0</defaultValue>
</stateVariable>
<!-- The Last User to initiate an event against the Partition.
An Alarm-specific string representing the "User" who last initiated a command against
the Partition (typically, but not necessarily) via a Keypad input to the Panel.
Partitions that don't support the notion of "Users" should leave this blank.
A Partition implementation may choose to blank-out the value of this stateVariable,
after any time period that seems reasonable, to meet local security requirements.
<name>LastUser</name>
<shortCode>lastuser</shortCode>
<defaultValue></defaultValue>
</stateVariable>
<!-- The Vendor Status (label) indicated by the Partition.
An Alarm/Vendor-specific string representing the Human readable "Status" last indicated
by the Partition.
This string may also show the Last status (label) of the Alarm Panel, and can be used
by UPnP Clients to display "progress" or current state.
eg. "Password not valid", "George's home is Arming", "Zones in Bypass 003, 004"
The string value is intended to be Human readable, as it may be presented within
a UPnP client's native display.
<name>VendorStatus</name>
<shortCode>vendorstatus</shortCode>
</stateVariable>
<!-- The Vendor Status Code indicated by the Partition.
An Alarm/Vendor-specific string representing the internal Status "code" last
These can also be used by "events" to provide Partition-specific mechanisms to
trigger things like "Fail to Arm" events and the like.
eg. "1378" (Elk) - "Rule Triggered Voice Telephone Dial"
eg. "658" (DSC) - "Keypad Lock-out"
eg. "040" (Paradox) - "Fail to Communicate on telephone Number"
The string value is intended to be used for Vendor specific scripting purposes. Consult
your specific Vendor for the set of Valid Vendor Status codes.
<name>VendorStatusCode</name>
<shortCode>vendorstatuscode</shortCode>
</stateVariable>
<!-- The Vendor Status Data for the Vendor Status Code.
An Alarm/Vendor-specific string representing the internal state "data", associated with
the Vendor Status Code above.
your specific Vendor for the set of Valid Vendor Status data.
<name>VendorStatusData</name>
<shortCode>vendorstatusdata</shortCode>
</stateVariable>
