many mid-range and higher routers have the ability to put one or more interfaces on a different network than the primary internal one. Sometimes its used for gaming or servers . (Do not put vera in a DMZ network allowing outside access) .
You could put vera behind a separate router for now, however unless you do some network tricks, all access will go through the Vera home.getvera.com servers.
