Has this been fixed?
Yes is has. I’m on FW version 1.7.1707 and the Qubino ZMNHDA2 has a working dimmer and the sensors report their status (don’t know about the temperature sensor).
However Qubino recently released their new Z-wave plus model ZMNHDD1 and this one doesn’t report back it’s sensor status on the vera.
It has a couple of options in the settings.
[code]
Parameter no. 100 ? Enable / Disable Endpoints I2 or select
Notification Type and Event
Enabling I2 means that Endpoint (I2) will be present on UI. Disabling it
will result in hiding the endpoint according to the parameter set value.
Additionally, a Notification Type and Event can be selected for the
endpoint. Available config. parameters (data type is 1 Byte DEC):
Endpoint device type selection:
- notification sensor (1 - 6):
GENERIC_TYPE_SENSOR_NOTIFICATION,
SPECIFIC_TYPE_NOTIFICATION_SENSOR
? default value 1
? 1 - Home Security; Motion Detection, unknown loc.
? 2 - Carbon Monoxide; Carbon Monoxide detected, unknown
location.
? 3 - Carbon Dioxide; Carbon Dioxide detected, unknown loc.
? 4 - Water Alarm; Water Leak detected, unknown loc.
? 5 - Heat Alarm; Overheat detected, unknown loc.
? 6 - Smoke Alarm; Smoke detected, unknown loc.
? 0 - Endpoint, I2 disabled - sensor binary (9): GENERIC_TYPE_SENSOR_BINARY,
SPECIFIC_TYPE_NOT_USED
? 9 - Sensor binary
NOTE1: After parameter change, first exclude module (without setting
parameters to default value) and then re include the module![/code]
I tried them all but without success. For now I’ve put it on option 9 (binary sensor) this is what the userdata file says over the sensor.
<device id="308" device_type="urn:schemas-upnp-org:device:DimmableLight:1" id_parent="1" embedded="0" disabled="0" device_file="D_DimmableLight1.xml" impl_file="" model="" altid="64" ip="" mac="" time_created="1454067952" category_num="2" subcategory_num="0" manufacturer="Goap d.o.o." name="Kinderkamer" room="2" device_json="D_DimmableLight1.json" local_udn="uuid:4d494342-5342-5645-0134-000002b034bb">
<states>
<state service="urn:micasaverde-com:serviceId:ZWaveDevice1" variable="Capabilities" value="211,156,1,4,17,1,L,R,B,RS,|32,37,38:3,39,48:1,50:4,89,90,94,96:4,112,113:5,114,115,133,134,142," id="0"/>
<state service="urn:micasaverde-com:serviceId:ZWaveDevice1" variable="ManufacturerInfo" value="345,1,81" id="1"/>
<state service="urn:micasaverde-com:serviceId:ZWaveDevice1" variable="VersionInfo" value="3,4,5,1,1" id="2"/>
<state service="urn:micasaverde-com:serviceId:HaDevice1" variable="Configured" value="1" id="3"/>
<state service="urn:micasaverde-com:serviceId:ZWaveDevice1" variable="NodeInfo" value="20,25,26,27,30,32,59,5a,5e,60,70,71,72,73,85,86,8e," id="4"/>
<state service="urn:micasaverde-com:serviceId:ZWaveDevice1" variable="MeterType" value="1" id="5"/>
<state service="urn:micasaverde-com:serviceId:ZWaveDevice1" variable="MeterScale" value="5" id="6"/>
<state service="urn:micasaverde-com:serviceId:ZWaveDevice1" variable="AlarmType" value="" id="7"/>
<state service="urn:micasaverde-com:serviceId:ZWaveDevice1" variable="AlarmVersion" value="1,0" id="8"/>
<state service="urn:micasaverde-com:serviceId:ZWaveDevice1" variable="SwitchMlSettings" value="2,0" id="9"/>
<state service="urn:micasaverde-com:serviceId:ZWaveDevice1" variable="PlusInfo" value="1,5,0,28,0,28,0" id="10"/>
<state service="urn:micasaverde-com:serviceId:ZWaveDevice1" variable="MultiChEndpoint" value="2,0,0" id="11"/>
<state service="urn:micasaverde-com:serviceId:ZWaveDevice1" variable="MultiChCapabilities" value="1,17,1,94,134,32,39,37,38,50,133,142,89,239,2,32,0,94,134,32,48,113,133,142,89,239,32,2,32,0,94,134,32,48,113,133,142,89,239,32,2,32,0,94,134,32,48,113,133,142,89,239,32,2,32,0,94,134,32,48,113,133,142,89,239,32," id="12"/>
<state service="urn:micasaverde-com:serviceId:ZWaveDevice1" variable="AgiInfo" value="X" id="13"/>
<state service="urn:micasaverde-com:serviceId:ZWaveDevice1" variable="Neighbors" value="19,22,24,25,27,31,41,51,53,65," id="14"/>
<state service="urn:micasaverde-com:serviceId:ZWaveDevice1" variable="LastReset" value="1454068183" id="15"/>
<state service="urn:micasaverde-com:serviceId:ZWaveDevice1" variable="AssociationNum" value="11" id="16"/>
<state service="urn:micasaverde-com:serviceId:HaDevice1" variable="ModeSetting" value="1: ,42;2:F;3:F;4:F" id="17"/>
<state service="urn:micasaverde-com:serviceId:ZWaveDevice1" variable="ConfiguredAssoc" value="" id="18"/>
<state service="urn:micasaverde-com:serviceId:HaDevice1" variable="LastUpdate" value="1454068193" id="19"/>
<state service="urn:micasaverde-com:serviceId:HaDevice1" variable="FirstConfigured" value="1454068193" id="20"/>
<state service="urn:micasaverde-com:serviceId:ZWaveDevice1" variable="PollSettings" value="60" id="21"/>
<state service="urn:upnp-org:serviceId:SwitchPower1" variable="Status" id="22" value="0"/>
<state service="urn:upnp-org:serviceId:Dimming1" variable="LoadLevelStatus" id="23" value="0"/>
<state service="urn:micasaverde-com:serviceId:HaDevice1" variable="ChildrenSameRoom" value="0" id="24"/>
<state service="urn:micasaverde-com:serviceId:ZWaveDevice1" variable="LastRouteUpdate" id="25" value="1455152770"/>
<state service="urn:micasaverde-com:serviceId:EnergyMetering1" variable="Watts" id="26" value="0.0"/>
<state service="urn:micasaverde-com:serviceId:EnergyMetering1" variable="Log" id="27" value="0,0,0,1455172200,1"/>
<state service="urn:micasaverde-com:serviceId:EnergyMetering1" variable="ActualUsage" value="1" id="28"/>
<state service="urn:micasaverde-com:serviceId:EnergyMetering1" variable="KWH" value="0.2000" id="29"/>
<state service="urn:micasaverde-com:serviceId:EnergyMetering1" variable="KWHReading" id="30" value="1455172643"/>
<state service="urn:micasaverde-com:serviceId:ZWaveDevice1" variable="PollOk" id="31" value="1141"/>
<state service="urn:micasaverde-com:serviceId:ZWaveNetwork1" variable="LastPollSuccess" id="32" value="1455172645"/>
<state service="urn:micasaverde-com:serviceId:ZWaveNetwork1" variable="ConsecutivePollFails" id="33" value="0"/>
<state service="urn:micasaverde-com:serviceId:ZWaveDevice1" variable="PollNoReply" id="34" value="800"/>
<state service="urn:upnp-org:serviceId:SwitchPower1" variable="Target" value="0" id="35"/>
<state service="urn:micasaverde-com:serviceId:ZWaveDevice1" variable="LastNnu" value="1455066000,8" id="36"/>
<state service="urn:micasaverde-com:serviceId:ZWaveDevice1" variable="LastArr" value="1455066000,8" id="37"/>
</states>
<ControlURLs>
<service_198 service="urn:upnp-org:serviceId:SwitchPower1" ControlURL="/upnp/control/dev_198" EventURL="/upnp/event/dev_198" serviceType="urn:schemas-upnp-org:service:SwitchPower:1"/>
<service_199 service="urn:upnp-org:serviceId:Dimming1" ControlURL="/upnp/control/dev_199" EventURL="/upnp/event/dev_199" serviceType="urn:schemas-upnp-org:service:Dimming:1"/>
<service_200 service="urn:micasaverde-com:serviceId:EnergyMetering1" ControlURL="/upnp/control/dev_200" EventURL="/upnp/event/dev_200" serviceType="urn:schemas-micasaverde-com:service:EnergyMetering:1"/>
<service_201 service="urn:micasaverde-com:serviceId:HaDevice1" ControlURL="/upnp/control/dev_201" EventURL="/upnp/event/dev_201" serviceType="urn:schemas-micasaverde-com:service:HaDevice:1"/>
<service_202 service="urn:micasaverde-com:serviceId:Color1" ControlURL="/upnp/control/dev_202" EventURL="/upnp/event/dev_202" serviceType="urn:schemas-micasaverde-com:service:Color:1"/>
</ControlURLs>
</device>
<device id="309" device_type="urn:schemas-upnp-org:device:DimmableLight:1" id_parent="308" disabled="0" device_file="D_DimmableLight1.xml" impl_file="" manufacturer="" model="" altid="e1" ip="" mac="" time_created="1454068195" category_num="2" subcategory_num="0" embedded="1" device_json="D_DimmableLight1.json" name="Kinderkamer -O" room="5" local_udn="uuid:4d494342-5342-5645-0135-000002b034bb">
<states>
<state service="urn:micasaverde-com:serviceId:ZWaveDevice1" variable="ManufacturerInfo" value="0,0,0" id="0"/>
<state service="urn:micasaverde-com:serviceId:ZWaveDevice1" variable="Capabilities" value="211,156,1,4,17,1,L,R,B,RS,|32,37,38,39,50,89,94,133,134,142,239," id="1"/>
<state service="urn:micasaverde-com:serviceId:HaDevice1" variable="ModeSetting" value="1:;2:;3:;4:" id="2"/>
<state service="urn:micasaverde-com:serviceId:EnergyMetering1" variable="Watts" id="3" value="0.0"/>
<state service="urn:micasaverde-com:serviceId:EnergyMetering1" variable="Log" id="4" value="0,0,0,1455172200,1"/>
<state service="urn:micasaverde-com:serviceId:EnergyMetering1" variable="ActualUsage" value="1" id="5"/>
<state service="urn:upnp-org:serviceId:Dimming1" variable="LoadLevelTarget" value="0" id="6"/>
<state service="urn:upnp-org:serviceId:Dimming1" variable="LoadLevelStatus" id="7" value="0"/>
<state service="urn:upnp-org:serviceId:SwitchPower1" variable="Status" id="8" value="0"/>
<state service="urn:micasaverde-com:serviceId:EnergyMetering1" variable="KWH" value="0.2000" id="9"/>
<state service="urn:micasaverde-com:serviceId:EnergyMetering1" variable="KWHReading" id="10" value="1455172634"/>
</states>
<ControlURLs>
<service_203 service="urn:upnp-org:serviceId:SwitchPower1" ControlURL="/upnp/control/dev_203" EventURL="/upnp/event/dev_203" serviceType="urn:schemas-upnp-org:service:SwitchPower:1"/>
<service_204 service="urn:upnp-org:serviceId:Dimming1" ControlURL="/upnp/control/dev_204" EventURL="/upnp/event/dev_204" serviceType="urn:schemas-upnp-org:service:Dimming:1"/>
<service_205 service="urn:micasaverde-com:serviceId:EnergyMetering1" ControlURL="/upnp/control/dev_205" EventURL="/upnp/event/dev_205" serviceType="urn:schemas-micasaverde-com:service:EnergyMetering:1"/>
<service_206 service="urn:micasaverde-com:serviceId:HaDevice1" ControlURL="/upnp/control/dev_206" EventURL="/upnp/event/dev_206" serviceType="urn:schemas-micasaverde-com:service:HaDevice:1"/>
<service_207 service="urn:micasaverde-com:serviceId:Color1" ControlURL="/upnp/control/dev_207" EventURL="/upnp/event/dev_207" serviceType="urn:schemas-micasaverde-com:service:Color:1"/>
</ControlURLs>
</device>
<device id="310" device_type="urn:schemas-micasaverde-com:device:MotionSensor:1" id_parent="308" disabled="0" device_file="D_MotionSensor1.xml" impl_file="" manufacturer="" model="" altid="e2" ip="" mac="" time_created="1454068195" category_num="4" subcategory_num="3" embedded="1" device_json="D_MotionSensor1.json" name="Kinderkamer 1" room="5" local_udn="uuid:4d494342-5342-5645-0136-000002b034bb">
<states>
<state service="urn:micasaverde-com:serviceId:ZWaveDevice1" variable="Capabilities" value="211,156,1,4,32,0,L,R,B,RS,|32,48,89,94,113,133,134,142,239," id="1"/>
<state service="urn:micasaverde-com:serviceId:SecuritySensor1" variable="IgnoreTripTime" value="2" id="3"/>
<state service="urn:micasaverde-com:serviceId:SecuritySensor1" variable="LastTrip" id="4" value="1455166244"/>
<state service="urn:micasaverde-com:serviceId:SecuritySensor1" variable="Tripped" id="5" value="0"/>
</states>
<ControlURLs>
<service_208 service="urn:micasaverde-com:serviceId:SecuritySensor1" ControlURL="/upnp/control/dev_208" EventURL="/upnp/event/dev_208" serviceType="urn:schemas-micasaverde-com:service:SecuritySensor:1"/>
<service_209 service="urn:micasaverde-com:serviceId:HaDevice1" ControlURL="/upnp/control/dev_209" EventURL="/upnp/event/dev_209" serviceType="urn:schemas-micasaverde-com:service:HaDevice:1"/>
</ControlURLs>
</device>
I’ll just wait till Vera fixes this in a future update.
