New Vera: Vera Edge
I have occasionally received Sunday delivery but don’t think it’s guarantied. Also my current email from Amazon says expected delivery on Tuesday (Prime 2-day) when the website shows in stock on Friday. Maybe it will show up earlier.
As a note, mine also said Delivery on the 9th. I was just noting that they had started Sunday delivery. I haven’t really paid attention though on which ones I get on Sunday (I get a lot of packages from Amazon, especially this time of year…LOL).
That said, I wonder if it’s going to be a normal thing or a Holiday thing. I really like that USPS has been doing more deliveries to me lately. I like my UPS guy and all (we are on a first name basis), but I think the Gov’t screwing with USPS so they can’t be profitable has gone on long enough. Hopefully Sunday deliveries bring in some extra cash and the guys delivering get a bit of extra cash as well.
Got my edge Tuesday. Ordered it a few days prior.
(jeez, what’s up the 5 challenge questions on this forum?)
I got my VeraEdge a few days ago… Coming from Vera2 was a pain in the butt… I had to exclude all my zones and re include them and start from scratch… Trying to install a backup from Vera2 did not work at all. I even had tech support try and few different things.
[quote=“gonzlobo, post:143, topic:183464”]Got my edge Tuesday. Ordered it a few days prior.
(jeez, what’s up the 5 challenge questions on this forum?)[/quote]
Don’t be put off; when you first get started, the system challenges you. After you make a few posts, things get easier :-). You have a post count of 1 … welcome to the forum!
really would like to hear more from people who got their Vera Edge. Is it worth the wait? how easy to migrate from UI5? can you stick with UI5? Any plugin incompatibilities (aside from UI7 issues?) ???
I have a Vera3 on UI5 that refused to upgrade to UI7 and keep my scenes and devices in tact. I got my VeraEdge Tuesday and this weekend’s project is to begin phase out of Vera3 to VeraEdge. I thought I saw somewhere I can used a saved UI5 network file and use it to restore VeraEdge? Hunting for that thread/post now…
Chuck
Chuck[/quote]
You are unlikely to find that information. VERA says it needs ui7 and your one of the first that has it. So all eyes are waiting for the early ones to test things out.
I’d swear I saw a post with how to go from an existing vera to a new vera edge… but now I can’t find the thread!!! UGH.
Yes, in that thread it requires you to upgrade your current vera to UI7 and then do a backup. You can not downgrade the Vera edge to UI5 most likely due to zwave chip and CPU differences.
  • Garrett
OK… gonna give it a go very soon!
My experiences thus far, much much better then when I installed UI7 back when it first came out a few months back, so far seems stable and almost everything working
I have both running side by side and I am moving items one by one to new system, I did not go the upgrade route
Items moved from veralite ui5 (1.5.622) to veraedge ui7 (1.7.850) without issue
Aeon Labs Aeotec Z-Wave Recessed Door Sensor (DSB54) (shows as motion sensor rather then door sensor, but works)
Aeon Labs Z-Wave Door & Window Sensor (DSB04100-ZWUS)
Aeon Labs Aeotec Z-Wave Minimote Remote Control, White (DSA03202W-ZWUS)
Aeon Labs Aeotec Z-Wave Smart Energy Power Strip (DSC11-ZWUS)
Aeon Labs Aeotec Z-Wave Multi-Sensor (DSB05-ZWUS)
GE Z-Wave Wireless Lighting Control Outdoor Module (45604)
2gig Z-Wave Programmable Thermostat (CT100)
Yale Security Real Living Electronic Touch Screen Deadbolt (YRD220-ZW-619)
GE Z-Wave Technology Wireless Lighting Control Fluorescent Light & Appliance Module (45603)
Aeon Labs Z-wave Smart Energy Switch (DSC06106-ZWUS) (the power reading are off, on\off works fine)
Schlage V N N SL Home Motion Sensor (RS200HC)
Items moved from veralite ui5 to veraedge ui7 with issues
Intermatic Home Settings Screw In Module (HA05C)
---- tunrs off but wont turn on
---- per this thread http://forum.micasaverde.com/index.php/topic,27534.msg205850.html#msg205850 is already fixed in future release
*** fixed 1.7.906
also added one new Zwave Plus device that partially worked
Zipato RGBW LED Z-Wave Bulb, with 5 Color Channels
---- turns on\off, dims, but no options for changing colors on gui, opened support ticket waiting response
there are some issue with my two cameras saying sometimes disconnected in dashboard, but they still seem to work fine
---- VistaCam PT Pan/Tilt IP Camera
---- VistaCamSD Wide Angle IP Camera
I also moved to VeraAlerts from the “Push Notification” plugin as VeraAlerts was easier to configure in ui7, this has worked well for alerts
was unable to re-add users I used in ui7 testing in past as no options to re-add exisitng users in UI7, so had to give them a new username and new email to add them
– this only applies to other admins of other vera’s, to add another main admin of a vera to ui7, you need to give them a new userid\password
http://forum.micasaverde.com/index.php/topic,28701.msg205653.html#msg205653
AutHomationHD 3.3.1.4 Beta is working good on ui7
http://forum.micasaverde.com/index.php?topic=25219.0
unable to manually set IP or disable built in wireless access point - opened issue with support
– had support disable wifi and set reserved IP on dhcp until resolved
*** fixed 1.7.906
You have a much newer Firmware version than is available to the Vera 3 users (1.7.439)
Same here , my VeraLite has a 1.7.439 version firmware.
Is there a list of compatible devices that work with UI7? If not, @JS007 is off to a good start.
According to MCV, EVERY Z-wave device is compatible ::slight_smile:
Well we know that’s not true. ::slight_smile:
Is this model going to be available in AUS frequency any time soon?
Has anyone successfully loaded a UI7 backup from a vera 3 or veralite? I am currently on UI7 on a veralite and get my vera edge today. I plan to load my vera edge with one of my backups. Assume this should just port over?
[quote=“Mgsmith75, post:159, topic:183464”]Has anyone successfully loaded a UI7 backup from a vera 3 or veralite? I am currently on UI7 on a veralite and get my vera edge today. I plan to load my vera edge with one of my backups. Assume this should just port over?
Sent from my iPhone using Tapatalk[/quote]
I’ll let you know IF the folks in tech support can ever get my Vera3 upgraded to UI7 and keep my existing devices, scenes and plugins too… so far it has been Fail… >:( .
