[quote=“waltzer11, post:20, topic:183464”]anybody knows if Veralite G is the latest/newest hardware?
http://getvera.com/controllers/veralite-g/[/quote]
Nope. A simple google search reveals the same exact specs.
[quote=“TC1, post:21, topic:183464”][quote=“waltzer11, post:20, topic:183464”]anybody knows if Veralite G is the latest/newest hardware?
http://getvera.com/controllers/veralite/#[/quote]
Regardless of it having the same specs as the VeraLite, the VeraLite G looks to be the same product that we saw the FCC filing for, right?
The VeraLite-G is just a VeraLite with Wifi added I believe.
The specs for processor, memory, etc are exactly the same as the current VeraLite, so regardless, there’s no point in buying one unless you want wifi incorporated into the unit (which most sensible folks don’t).
[quote=“TC1, post:23, topic:183464”]The VeraLite-G is just a VeraLite with Wifi added I believe.
The specs for processor, memory, etc are exactly the same as the current VeraLite, so regardless, there’s no point in buying one unless you want wifi incorporated into the unit (which most sensible folks don’t).[/quote]
This is really sad… A VeraLight with Wifi is EXACTLY what we DON’T want… another variable to debug, just so you can locate your Vera in the garage?!?
Guys check this reply on the Vera [url=https://www.facebook.com/veracontrol]https://www.facebook.com/veracontrol[/url] post from today (08-11-2014)…
The post is called:
“Great CE Pro write-up on Vera Control, Ltd. and MiOS powering the Homelive Smart Home Solution that went on sale last week in all Orange retail stores throughout France.”
There is a question and reply:
Q: Looking at the pictures, it seems to be the “new” Vera that has been speculated about on the forum, the one with the ZWAVE+ chipset. Can you confirm this?
A: Great question Benjamin. Yes, I can confirm the new VeraEdge is a Z-Wave Plus? controller, but it is not (as some have speculated) the HAB that Orange has deployed for Homelive.
We’ll announce full details on the VeraEdge next week. Stay tuned.
Cheers,
Colin Burke McClure ▾ Sr. Director of Product Development
What do you think of that?!
I think it’s a vera lite with with z-wave plus. Lacking in ram and hardware perfomance. And as far as the next week time frame… Yeah OK
Well sleuthed, Sherlock.
I can’t take credit, all revealed on the forum a while ago… http://forum.micasaverde.com/index.php?topic=26451
This is the 3rd such thread that I remember.
I just pre-orded a Vera Edge ETA December 2014… keep you all posted.
cheers,
mc
[quote=“mcalistair, post:30, topic:183464”]I just pre-orded a Vera Edge ETA December 2014… keep you all posted.
cheers,
mc[/quote]
Didn’t even know that was an option yet or the pricing was out. I’m searching the site, but maybe you can post the info/link.
Here is the link: http://www.robbshop.nl/vera-edge-basisstation
Some specs:
Network
Ethernet 1 WAN Port (10/100Base-T)
Wireless WiFi: IEEE 802.11n
Z-Wave: Built-in US/EU Z-Wave Module
Software
Applications Linux 2.6 BSP Ready
Hardware
Processors and Memory
600MHz MIPS SoC
NAND Flash: 128 MB
Memory: DDR2 128 MB
Connectors
1 DC Power Jack
1 RJ-45 Connector
1 External USB Connector
LED and Button
LEDs: Power, WAN, WiFi, Z-Wave, Service
Buttons: Reset, WPS, Sync
Antenna
2 WiFi Internal Antennas
1 Z-Wave Internal Antenna
Power Adapter
Input: 100-240VAC, 50-60Hz
Output: 12VDC, 1A
Compliance
FCC, CE
Dimensions
(H x W x D) 115.5mm x 79.5mm x 30.5mm (4.55" x 3.13" x 1.2")
cheers,
mc[/quote]
From where?
I was hoping to see more DDR memory…
That’s the most serious limit on Vera … you can try to swap to the FLASH … but that memory is not really designed for LARGE # of write cycles.
[quote=“TC1, post:33, topic:183464”][quote=“mcalistair, post:30, topic:183464”]I just pre-orded a Vera Edge ETA December 2014… keep you all posted.
cheers,
mc[/quote]
From where?[/quote]
Robbshop.nl indeed… http://www.robbshop.nl/vera-edge-basisstation
[quote=“RichardTSchaefer, post:34, topic:183464”]I was hoping to see more DDR memory…
That’s the most serious limit on Vera … you can try to swap to the FLASH … but that memory is not really designed for LARGE # of write cycles.[/quote]
Agreed. From what I can see and experienced with Vera, product planning has always been short sighted, both from the hardware and software side. Tis a shame.
Because of the # of usb ports and same mermory as the 3 it doesn’t seem like an upgrade to the 3 (besides z-wave plus).
Seems like only a veraLite upgrade, without a 3 upgrade in sight.
It’s almost here!! http://www.amazon.com/dp/B00PFGJZM8/?utm_source=facebook&utm_medium=post&utm_campaign=veraedge_amzn_excl
Not much of an upgrade is it… :
