We have launched new relay servers in New Jersey and currently assigned about 5% of G series controllers in the US to these relays.
Should you encounter any issue - remote access through web or mobile app, voise assistants commands failing or anything else - please make sure to reach out to our customer care team, so they forward the requests to the persons in charge.
@JonathanB - thank you for the clarification. It would be great if you can assign my 3 Vera Plus controllers to the New Jersey servers because all of my controllers are all on the east coast in the US. I’m sure the more proximal servers will offer much better performance than the current servers in Romania and I will be happy to report any issues if not.
Do you guys maintain a url for a text file that contains CIDRs or IP addresses that host the MIOS services (similar to this from Google https://www.gstatic.com/ipranges/goog.txt)? The impetus is that I would like to configure my firewall to limit my Vera controller to the Vera MIOS host IPs and my Ezlo controllers to the Ezlo MIOS host IPs.
If not, can you provide me with the IPs/CIDRs for the servers to which my Vera and Ezlo controllers connect? I realize that they could change so there is risk that my controllers will go offline as a result but hopefully you can point me to a url that contains the dynamic IP address list you deploy and manage.
Seems things to be working fine with the new servers however I am experiencing delayed email notifications. For example, I received several emails at between 11 PM and 2 AM for events that happened in the morning and afternoon prior. I don’t know if this has anything to do with the new servers that my Vera Controller is paired with but I thought I would let you.
Same here. The notification from the “Fritz!Box Call Log” plugin only arrives hours later. It also takes a very long time until I get a connection to the controller despite a local connection:
The local connection issue should not be related to the relay since it tries local first. I am going to recheck the notification queue issue as I saw delays increased again.
