According to vera website the Netatmo weather station an Vera are a perfect match.
I just did the normal “add device” and completed the procedure.
I can see 2 devices, the indoor and outdoor module, the wind gauge is totally missing.
The indoor module is showing all the measurements: temp, co2, humidity, noise, pressure just fine.
But the outdoor module is not showing any values of the outdoor sensors, instead it shows the indoor temperature and humidity.
I always carefully investigate the compatibility with Vera before I buy any devices.
(Can’t even imagine what would happen if I bought a device that’s not in the compatibility list)
But there is still some problems with every single device I bought so far.
I am really getting sick of this lack of compatibility.
Vera has it’s own problems as we all know, but then when you add all the compatibility issues etc. to this - It’s a total mess.
I know it’s not just a Vera problem, all systems have their problems.
Every single time I ask Alexa to do something, or use the Vera app to do something, there is this feeling in the back of my head:
“will it work?” “wonder how long the delay is this time?” etc.
You can’t rely in these systems at all! and that drives me crazy!
If I had known all this before I got into automate my home, I wouldn’t have even considered to start!
But it’s too late to quit now, and I’m not going to stop at any cost. ![]()
Sorry for this venting, I just had to.
So, Is there any possibility to get this working properly?
Have read about the plugin available by akbooer. Is that required?
