Netatmo weather station not working
Any letter other than THCPNRW should do… say, X?
What do they mean by ‘blank’? Would a single space also work? (I don’t use the latest firmware!)
Not working.
Or, another way - it wiped out all devices created by plugin.
Of course in each device’s “children” I’ve put names of variables I want to have reprted ad child devices, like IndoorChildren: IndoorTemperature, IndoorHumidity, IndoorCO2 (by the way, I don’t know what to do with battery status - should I write it as separate device, or it will be reported as an icon on the upper-left corner of temp. device anyway?)
Single space doesn’t work, I’ve tried it already. Any letter single or digit is accepted
I tried to change these data via AltUI (there I can leave the variable empty), but any changes are ignored (not saved).
Yes, I’d expect it to do that… I thought that was what you wanted?
Having done so, the individual child devices specified should be created.
The battery level should be reported as usual in every child device that belongs to a module with a battery.
[quote=“akbooer, post:23, topic:198811”]Yes, I’d expect it to do that… I thought that was what you wanted?
Having done so, the individual child devices specified should be created.[/quote]
They didn’t.
All child devices were wiped out and none were created in place of them, regardless of specified variables in xxxxChildren variable for specific modules
That’s surprising… it works for me.
Do you have the syntax right? I have, for example:
[tt]GardenRoomChildren MaxTemp, MinTemp, DewPoint[/tt]
…which gives me the result attached.
I did as you guided earlier:
The full names, since you might have, say, IndoorTemperature, OutdoorTemperature, GuestTemperature, ...
When I changed it to “Temperature” for specific child device, new devices were created ad everything works now.
Thanks!
