I had a Netatmo connected to a vera3 without issue. I replaced the vera3 with an Edge. From a site not on the LAN I installed the Neatmo plugin and tried to use the client ID and secret I used with the vera3. I got “authentication failed.” I registered a new app with Netamo and used the new id and secret. I still get “authentication failed” Is this because I am not on the LAN as I set it up, or because the Netatmo was previously used with a different controller?? I went through this once before with the Vera 3 without issue. Is there an issue with the Edge? Any thing that I should try? Thanks
Not sure I get your meaning here.
I got "authentication failed." I registered a new app with Netamo and used the new id and secret. I still get "authentication failed" Is this because I am not on the LAN as I set it up, or because the Netatmo was previously used with a different controller??The Netatmo itself doesn't know anything about the controller accessing it. It doesn't have to be on the same LAN as Vera since all the access is via the WEB API over the internet. I have two separate Veras accessing the same Netatmo stations (using separate client IDs) just fine.
I went through this once before with the Vera 3 without issue. Is there an issue with the Edge? Any thing that I should try? ThanksI'm on UI5 and don't have UI7 or an Edge. Maybe I need to ask Vera to supply me one for development. So I can't comment on any Edge issues, although I see that others have quite successfully run under UI7.
A recent problem someone noticed was that their Netatmo firmware was not up to date - perhaps something to look at. Also, what version of the Netatmo plugin are you using?
Sorry if not clear. In Boston I switched from Vera3 latest firmware and UI to an Edge. I am using the Vera3 here in FL. The Netatmo has latest firmware. I did not attempt to install the Netatmo plugin on the Edge because I had to leave Boston right away. Here in from Florida I installed the plugin on the Boston Edge and tried to use the Client ID and Secret I had used with the Vera3. The UID and PWD were carefully checked and the ID and secret were triple checked. The UI showed that the data was updated yet the authorization failed. I logged in and out several times. The device was not found as well. I though that maybe the Client ID and secret might be now linked the the Vera3 so I set up a new app on the Netatmo site and got a new Client ID and secret. Those were entered using cut and paste to be certain that there was no mistyping. Again the device is not found and authentication fails. Again I logged in and out several times.
I had the Netatmo working fine with UI7 and the firmware is the latest. Is there something else that I should check? I used a Client ID in the Edge that had been used previously in the Vera3. Any issue there. Do I need to do anything physical to the Netatmo or Edge that I can’t do remotely? BTW the plugin is brilliant. Access to the sound level is crucial for my needs.
Ah, much clearer now. Is this perhaps the “Can’t find device” problem previously reported in this thread (since you mention that the data is updating)? You don’t mention the app version that you’re running. Try loading the Lua file attached to this post: [url=http://forum.micasaverde.com/index.php/topic,16276.msg203657.html#msg203657]http://forum.micasaverde.com/index.php/topic,16276.msg203657.html#msg203657[/url] if you’re a few versions behind. The .json file on the subsequent post to that also sorts out some of the UI look and feel issues that there were in UI7.
Give it a go. Otherwise we’ll try and think of something else.
Hello,
I’ve just received for Christmas a Netatmo Weather Station.
I have tried everything to make it work, but I didn’t manage.
Can you help me ?
My Vera Lite is running UI7.
The Netatmo seems to have the latest firmware (it made an update yesterday).
The plugin is the one from the store.
First, I update the xml file, because the advanced tab was empty :
http://forum.micasaverde.com/index.php/topic,16276.msg203368.html#msg203368
After that, I can configure the 4 parameters :
local s_client_id = “XXXXXXX”
local s_client_secret = “XXXXXXX”
local s_username = “my-Netatmo-mail-account”
local s_password = “my-Netamo-password”
I update the lua file from this thread : http://forum.micasaverde.com/index.php/topic,16276.msg204020.html#msg204020
and the .json files from this thread : http://forum.micasaverde.com/index.php/topic,16276.msg203683.html#msg203683
I reload a after each modification, but without success.
I’ve got the message :
Netatmo Lua Failure Can’t Detect Device
50 12/25/14 15:27:17.698 luup_log:50: Netatmo: Netatmo initialisation… <0x2be92680>
50 12/25/14 15:27:18.237 luup_log:50: Netatmo: HTTPS error = 400 <0x2be92680>
50 12/25/14 15:27:18.237 luup_log:50: Netatmo: Authorisation failed <0x2be92680>
06 12/25/14 15:27:18.237 Device_Variable::m_szValue_set device: 50 service: urn:micasaverde-com:serviceId:HaDevice1 variable: CommFailure was: 1 now: 2 #hooks: 0 upnp: 0 skip: 0 v:0xe025e0/NONE duplicate:0 <0x2be92680>
06 12/25/14 15:27:18.238 Device_Variable::m_szValue_set device: 50 service: urn:micasaverde-com:serviceId:HaDevice1 variable: CommFailureTime was: 1419512750 now: 1419517638 #hooks: 0 upnp: 0 skip: 0 v:(nil)/NONE duplicate:0 <0x2be92680>
01 12/25/14 15:27:18.240 LuaInterface::CallFunction_Startup-2 device 50 function init failed Netatmo with return false <0x2be92680>
06 12/25/14 15:27:18.240 Device_Variable::m_szValue_set device: 50 service: urn:micasaverde-com:serviceId:HaDevice1 variable: CommFailure was: 2 now: 1 #hooks: 0 upnp: 0 skip: 0 v:0xe025e0/NONE duplicate:0 <0x2be92680>
06 12/25/14 15:27:18.241 Device_Variable::m_szValue_set device: 50 service: urn:micasaverde-com:serviceId:HaDevice1 variable: CommFailureTime was: 1419517638 now: 1419517638 #hooks: 0 upnp: 0 skip: 0 v:(nil)/NONE duplicate:1 <0x2be92680>
01 12/25/14 15:27:18.242 LuImplementation::StartLua running startup code for 50 I_Netatmo.xml failed <0x2be92680>
02 12/25/14 15:27:18.242 UserData::AlarmCallback ALARM_RESYNC_DEVICES <0x2be92680>
Netatmo plugin installed into Veralite running UI7 - check!
Plugin registered at Netatmo.com - check!
Client ID and Secret obtained. - check!
“Critical fields to be filled” as per post 1 of this thread. - ???
Where do I do this? The Settings, Advanced, and Options tabs are all blank. What am I missing?
I had the same problem.
You have to replace the xml files.
Look at the first link of my post before yours.
Did it work, or are you still having the same problem?
I manage to configure the 4 parameters (the advanced tab is no more empty).
But it didn’t work
Nestor, did you manage to make it work ?
I always have the connexion error…
No. I gave up. ![]()
I assume we are talking UI7, that you have the latest firmware in your Netatmo, and you installed the latest plugin from the App Store.
You may be seeing an error previously reported (and fixed), so you you haven’t tried it, take a look at this post [url=http://forum.micasaverde.com/index.php/topic,16276.msg203657.html#msg203657]http://forum.micasaverde.com/index.php/topic,16276.msg203657.html#msg203657[/url] and download the Lua file attached there.
Others have got this working OK under UI7, so there shouldn’t be a fundamental problem. The initially blank panels after installation should get sorted by a restart.
Hi akbooer,
Yes, I am under UI7 (the latest firmware).
How do you know if the netatmo station have the latest firmware ?
I think it’s the case, but I am not sure.
To make a clean install, today, I have uninstall the netatmo plugin.
I have reinstalled the plugin from the store, reboot several time (with the button on the interface : settings => net & wifi), but, the advanced tab of the device “netatmo” is empty :-(.
I use IE11, do you think it’s the problem ?
Previously, I had replaced the D_Netatmo.xml file and the advanced tab was no more empty.
I am not at home, it will be easier to test next sunday.
I have updated D_Netatmo.xml, and Advanced tab is no more blank.
I took the file from this post :
The device type need to have uppercase :
before : urn:akbooer-com:device:netatmo:1
after : urn:akbooer-com:device:Netatmo:1
Now, I have completed the 4 fields and I have this message : “Netatmo : Authorisation failed”
And in the log : “Username or password not set, device:Netatmo (#50) in is offline. …”
Yes, that’s what you need to do to run under UI7. You may also choose to update the .json files from here: http://forum.micasaverde.com/index.php/topic,16276.msg203683.html#msg203683
I took the file from this post : http://forum.micasaverde.com/index.php/topic,16276.msg203368.html#msg203368 The device type need to have uppercase : before : urn:akbooer-com:device:netatmo:1 after : urn:akbooer-com:device:Netatmo:1OK thanks, I thought that was fixed. But, again, not having UI7, I can't be much help here!
Now, I have completed the 4 fields and I have this message : "Netatmo : Authorisation failed" And in the log : "Username or password not set, device:Netatmo (#50) in is offline. ....."OK, well that's a genuine authentication failure - so something wrong with username or password, or IDs. I'd recommend that you don't have any "special" characters in your password (international character sets, ... just stick to alphanumerics.)
The setting page of Netatmo’s own handheld app shows the firmware version number - good to check you’re up to date.
I try to change the password : that was not the problem.
So, I have made a second account (new e-mail, new password, new clientID, new clientSecret), and it works ;D
I have all my Netatmo devices.
Sunday, I will put the icons at the good place.
Can you tell me where can I find all the icons ?
This thread http://forum.micasaverde.com/index.php/topic,16276.msg179917.html#msg179917 ?
Thank you for your help.
I am still unable to get my Netatmo to communicate after the upgrade from UI5 to UI7.
- First I deinstalled and reinstalled the App
- Uploaded the XML and LUA files to fix the issues with the blank advanced tap
- Upgraded the firmware on my netatmo
- setup new netatmo dev account
- reboot
After all this I still cant authenticate to the Netatmo account. Also, the icons are missing from Ui7, I found there is meant to be a zip of the icons but I can not locate it on the forums, just the reference. - I manually SCPd the files after I located the zip trawling the forums - so thats OK.
“Netatmo : Authorisation failed” is the error i received.
Do you have anything other than alphanumerics in your password? If so, change to something without them.
For me, the problem was the email :
- a dot in the first part of the mail (before @)
- or the length : 25
[quote=“Supermilk, post:19, topic:185616”]For me, the problem was the email :
- or the length : 25[/quote]
Ah, interesting. I’ll take a look at that, thanks.
