Hi, I just got a Vera Edge controller and a Neo Coolcam Motion Sensor. Tried to connect it pairing to the Vera Edge but it is not recognized as it should be, a sensor of motion.
It only allows me to define a scene when it is switched ON or OFF, no options about motion detecting.
As it is not in the Vera Edge list of devices, I tried to define it as the ones more similar: Fibaro 4 in 1 and Doom Motion Detector (that, by the way, I found in another topic that worked for another users of it).
But no way, it takes the icon of a “General Z-Wave device” and only accepts ON or OFF
Am I doing anything wrong? Should I give back it to the seller?
Waiting for the 24 hours lap time suggested. I will update.
By the way, I have same situation with the Neo Coolcam Door/Window sensor. Also defined as Doom Door/Window sensor because it seems to be, at least externally and internally, identical.
[quote=“cw-kid, post:10, topic:199299”]It might just be a case of editing the Neo CoolCam door / window device with the correct properties for that type of device:
This is exactly what I did, taking the data from the example that comes with the Vera Edge Dashboard, BUT, I feel it doesn’t work correctly, it doesn’t detect when the magnet is separated from the detector, this is the reason I addressed support too.
BTW, I do believe that the device_json parameter should be D_DoorSensor1.json (not .xml in this one)
Additionally, in the example included in the dashboard, the id_parent and the embedded parameters are used. In the “generic” one to-be-modified it is not and I didn’t change it?. Do you know if I should change also them?
Let me copy here how is MY “Door/Window sensor” defined in the ref. parameters:
id_parent 1
nobulk
embedded
disabled
restricted
device_file D_DoorSensor1.xml
id 25
And this how it is defined in the example that comes with the dashboard:
id_parent 25
nobulk
V embedded (marked)
disabled
restricted
id 26
Similar differences can be found in my definition of “Motion Sensor” and the one as example in the dashboard. Motion works, Door seems not to work.
Anyway, are you or any other one able to explain what is the meaning of those parameters and/or the importance and influence of their values? Is it normal that the id of my door sensor is at the same time the id_parent of the example? In the case of the motion sensor there is no relation between them.
[quote=“cw-kid, post:15, topic:199299”]So in your case the device with id # 26 is the child device.
The device with id # 25 is the parent device.
I would modify the parent device as discussed and if that then looks correct and works as a door sensor?
Just hide the child device from the UI7 GUI.[/quote]
This is the definition in the dashboard example (not my actual device), In my device it is not that of my real device id # 1 for the parent and id # 25 the child.
What seems to be strange for me is that “my id # 25” is the “parent device” of the example?
Aditionally, is your final definition of the sensor similar to mine? With a number in the id-parent and all the subparameters (included the embedded one) unmarked?
Here is my letterbox door sensor device. The parent is the device I modified as described here and the child device is normally hidden from view as it’s not required.
Parent Device:
name
Letterbox
device_type
urn:schemas-micasaverde-com:device:DoorSensor:1
altid
63
ip
mac
manufacturer
model
id_parent
1
nobulk
embedded
disabled
restricted
device_file
D_DoorSensor1.xml
id
206
impl_file
time_created
1510768663
room
3
poll
category_num
4
subcategory_num
1
device_json
D_DoorSensor1.json
Child device:
name
Letterbox Child
device_type
altid
b10
ip
mac
manufacturer
model
id_parent
206
nobulk
embedded (This is ticked on the child device)
disabled
restricted
device_file
D_DoorSensor1.xml
id
207
impl_file
time_created
1510768671
category_num
4
subcategory_num
1
device_json
D_DoorSensor1.json
room
3
BUT I have several differences from my side. I don’t have any “child” device in my devices, not in the real ones, not in the examples that come with the Dashboard.
I tried to have a look to the Lua code you refer to for the case they are hidden, but, as I could expect, there is nothing, it is intended only for adding user code.
The problem with the Neo Coolcam motion sensor and the Heiman HS1DS-Z door sensors I have, is that when these devices are paired to Vera it adds them as two devices instead of one, hence the need to manually do the modifications on the parent device and then hide the child device.
If you only have one device for the Neo Coolcam door sensor then that’s how it should be.
For example when I added my Sensitive strips door sensors they were correctly added as only one device.
