I finally thought about a way to understand how and when the “example” devices were created, and the manufacturer is blank in all of them. Maybe the altid says something, but I found the “time created” parameter, and there are interesting findings there. The time of creation of the THREE (yes, there are three) examples and my real ones are quite similar. In order to lower figure to highest they are:
Device# Name Example? altid Time created
25 MY door sensor NO, it is mine 9 1528529921
25/26 Door Sensor YES b10 1528529924
27 MY motion sensor NO, it is mine 7 1528530248
27/29 Motion Sensor YES b12 1528530252
27/28 Light Sensor YES m3 1528530252 (yes, same timestamp)
Looking at it my question is: might it be that the devices 25/26 was the real pairing of my NEO Door sensor and the 27/29 and 27/28 were the real pairing of my NEO motion sensor (that I feel it is really a motion/light sensor)???
I am saying they were examples because they were something I really didn’t do and what I saw as result of the pairing were the Z-Wave Generic device with only ON/OFF and the name I was giving to it in the pairing process. And then why the new “Generic Z-Wave” device with the device name I gave in the pairing process came???
To be honest, your comment about “No examples seen” and the coincidence of device id# and timestamps are giving to me reasons for thinking about it. Are possibly the devices 27/29, 25/26 and 27/28 (parent/child) the real ones installed and paired, even they didn’t take the name I did in the pairing process?
More investigation done. The “local-udn” parameter, that seems to be tighted to the devices themselves, is a long parameter, identical in all the five devices except one of the ?hexadecimal? digit in the fourth group of digits (for digits), so, again, it points to be devices generated when the new NEO ones were paired? but, again, what about the “generic one” and which one has to be controlled, the ones that took the name I defined in pairing or the other with a “standard name” ones?
I have to do some tests tomorrow, for the time being it is time to some relax.
Regards.
Javier
