ok.
Did you ever manage to address this issue? I am in the same situation and struggling to correct this. Vera support are also having a hard time with this.
The only workaround I found was to create a virtual temp sensor based on the local temperature brought by the system (based on my geo localisation). So, in fact I am only using this device to switch on the lights at night when someone moves around…
Regards
JM
Thanks for your response. I was hoping that a solution would have been found. But I guess not.
My suspicion is that the Vera firmware has not been coded properly to take into account the features of this sensor.
same issue
