I’m hoping someone here can help. I have several Qubino Flush Thermostats (v2) installed in my home and would like to know when they are actively heating and when they are not. (not whether they are in heat mode, because they could be in heat mode and have met the setpoint and therefore have turned off the heat). I also have 2 TKB Home thermostats, so I know there is a variable named “ModeState” that provides exactly this information - it’s value is either “Idle” or “Heating.” Here is the problem (actually 2):
- It seems with the Qubino, this variable is never updated - just stays at Idle all the time no matter if the desired temperature is way above the current temp or not.
- Out of my 6 Qubinos, 2 of them don’t even have the ModeState variable!
Any suggestions for how I can get this working? I need to know if the heat is actually being drawn or not.
