Is there any way to edit the dashboard? Ie move icons or change the size of icons.
No would be the simple answer. For a better looking layout, try the AltUI app.
Hello @Gary Gary,
Just to clarify, do you mean the Ezlogic Dashboard or the Vera dashboard?
The dashboard is mios app not the vera app dashboard.
Is there a preferred app to use on mobile devices?
It seems to be possible to design a dashboard in the web frontend. This should then also be able to be used in the MiOS app. At least in theory.
Letâs take a look at the current status:
When you click on the three bars in the Dynamic Dashboard, there is a button âCreate Dashboardâ
Then there is a choice of two options/designers for the dashboard (a cancel button should be added here):
The integrated designer has been around for a while now and it seems to be available again. It looks like this, for example:
Unfortunately, I donât know whether you can currently create a functioning dashboard with it. It seems extremely complicated to use and unfortunately there are no instructions/tutorials. I once had a video conference where it was shown to me, but the very next day I couldnât recreate it.
The Nucal Studio:
After registration, a verification email should be sent. But none arrives. I think I got to the designer itself, but I couldnât fill it with content. So it doesnât seem to be working yet.
It´s incredible so long the EZLO plus is in the market and there isn´t any APP than run OK.
An update on the status or plan for the Dashboard Designer would be great. Perhaps someone from Ezlo could comment on this. Itâs getting too quiet here in the forum again ![]()
Hello,
We have replicated this issue with NuCAL registration and have asked the developers about it. We will keep you posted.
In the meantime, could you try using the âDesignerâ mode, please? This is a video (link) from a year ago, but it should be a good guide to get started.
Iâve tried creating a Dashboard with the Designer. But there doesnât seem to be any way to save.
In the video it looks like this:
The save symbol and others are missing for me:
Iâve just tried again at home. Here Iâm able to save the Dashboard. At work there are no symbols displayed (both Chrome Browser). Iâm checking tomorrow at work again.
The whole dashboard situation is in a bit of a mess unfortunately. That Designer in the Ezlogic you are trying to use, never fully worked for me when I tried it, I wasnât able to create a custom dashboard / pages with it or have a navigation menu. I heard that Designer was being scrapped.
Also the Dynamic Dashboard in the Mios mobile app is being scrapped soon and they are going back to the old style dashboard that we had in the Vera mobile app.
EDIT: This was incorrect, actually in the Mios app they have scrapped the Dynamic Dashboard, but replaced it with a new âNative Dashboardâ. Native meaning it is written in native iOS code or something like that, is what they were saying.
Not sure if the Dynamic Dashboard is staying in the Ezlogic web UI ?
The Nucal Studio designer (the other one) is more likely to be the way we will create a custom dashboard. I also tried that and had issues with it. There was no easy way to create dashboard pages and a navigation menu system. And I could never get the device tiles to work properly in regards to having their states change when the device state changed.
So it seems Ezlo are quite behind currently in having a working dashboard solution.
It would be nice if someone from Ezlo could comment on this. What is the plan? Where are we going? And is there a roadmap?
Honeywell T6 thermostat.
Behavior on mios iOS app is inconsistent between dashboard view and device view.
The dashboard view is a mess and set the temp to 68 every time
Devs have been made aware of the Thermostat issues in the new iOS âNative Dashboardâ in the Mios app.
How do I rearrange the tiles in the redesigned dashboard for iOS version of the MIOS app?
All I can seem to do is toggle the show/hide offline devices.
Dont think you can rearrange the tile positions.
They need to make some improvements obviously. Especially like being able to sort by rooms and device types etc. And also to be able to hide devices / tiles you dont want to see.
Probably the wrong thread for but if I try and create a cloud meshbot using the MIOS app the Trigger box is just not there. Youâd think you should be able to create a simple meshbot that would trigger off of the geofence?
It seems like nothing is finished and stuff is only half done.
Clicking on virtual switch on dashboard does not toggle its state on/off
Also it tells me that itâs not associated to any mesh bots. This is if you click on the right arrow on the device and you see the device name and assigned to room and mesh bots and if you click on the right arrow for mesh bots it says its not assigned to any mesh bots.
Oh and when I created a virtual switch the first one never showed up under devices and I had to create another one and this one did show as test_switch 2 so I donât know what happened to 1
Also when trying to delete events you get an error when tryin to delete but it appears to delete but the just disappear from the screen and when you reenter âAlertsâ they come back same as of you multi select.
Iâm not sure whoâs testing this stuff internally but it seems they need more oversight.
