It’s working for me now!
Edit: Well, mios.com is forwarding correctly and I can access vera through it through the internet and it forwards to the local IP correctly to. This afternoon I did change vera’s ip to match the IP mios thought it was. Perhaps that helped? I tried using cp.mios.com after doing that and it didn’t seem to make a difference.
iVera crashes when trying to connect, and backups still fail.
So, all is not well still.
I have version 1.1.1327. MCV.com still reports it as 1.1.1267. The most current beta version is now 1.1.1332. While I’m eager to see if the new one fixes things, I’m worried not being able to create a backup. Not hearing anything from MCV doesn’t help anything either.
Edit2: Arrg, trying to do the firmware upgrade through Premium Domain Broker - DNX.com results in an empty page. Trying to do it through ui4 fails to, as it tries to download stuff from mios.com, which of course fails. This results in an empty firmware window.
I checked the NetworkMonitor log and it’s showing a problem with tunnels?
[tt]-rw-r–r-- 1 root root 23971 Jul 12 08:48 zwave_products_sys.xml
-rw-r–r-- 1 root root 49 Jul 19 13:24 zwave_version
err: <0x400>
02 07/19/11 20:32:49.464 CheckFreeTunnels file gone response 0
output:-rw-r–r-- 1 root root 0 Jul 16 15:07 320.reset
[/tt]
…more file list…
and this later on:
err: <0x400>
02 07/19/11 20:33:10.633 CheckPaidTunnels: restarting tunnels 0 / 0 <0x400>
02 07/19/11 20:33:10.634 Logger::Suspend <0x400>
02 07/19/11 20:33:13.008 Logger::Resume <0x400>
02 07/19/11 20:33:13.008 NetworkMonitor: CheckPaidTunnels required handling <0x400>
02 07/19/11 20:33:13.077 CheckFreeTunnels file gone response 0
[/tt]
and the file list continues until it shows the first error again. it shows the first error/file list repeatedly, and occasionally the second one.
Edit:
Waaaaahhhhh, I tried enabling failsafe ssh tunnels and it switched to the “Directly to the internet. MiOS is a gateway.” option and I can’t set it to anything else again.
