MiOS App Update for Android version v1.114.0.821
MiOS Android App v1.114.0.821
New
  • MeshBot now support improved labeling and filtering on mobile devices.
  • Improved information display for OS level notifications on MiOS.
  • Local and Cloud Meshbots can now be duplicated in the MiOS App.
  • Improved onboarding flow for EzloPi mobile apps.
  • A new Water Valve category has been created for Z-Wave DPWs.
  • Updated device icons on the devices list screen.
  • Improved UI representation for Ezlo Aware item types.
  • Native Dashboard now supports displaying online and offline devices.
Fixes & Improvements
  • The device adoption process on EzloPi is fixed, preventing it from getting stuck due to an empty MAC address.
  • Newly added EzloPi devices now display immediately without needing to restart the app.
  • Fixed a double login issue in the app, enhancing the user login experience.
  • Fixed a crash in Mios Live when selecting a specific date as an activation event.
  • Fixed an issue where selecting ‘Once’ in the Date and Time node of Meshbots displayed an incorrect future date.
  • Fixed issue preventing the device status from updating correctly on the Devices screen.
  • VistaCams 703 and 1103 no longer appear under More > Doorbells in Mios.
  • The Smart Plug-In Outlet now displays the correct icon under Devices and is available on the Dashboard.
  • Creating a notification user now correctly assigns notification-only permissions instead of admin privileges.
  • Fixed an issue where the thermostat icon was not displayed properly.
  • Fixed the icon and value display for the Swidget Pressure sensor.
  • The scale displayed for the Swidget Air Quality Sensor has been corrected to IAQ.
  • Decimals for Swidget Air Quality Sensor values are now displayed without rounding.
  • Swidget Air Quality Sensor now displays a maximum of 2 decimals and includes pollution level descriptions from “Excellent” to “Dangerous.”
  • Updated the Swidget Humidity Sensor icon in the MiOS app to match the design.
  • Device tiles are no longer cut off at the bottom of the native dashboard.
  • Fixed an issue preventing the addition of controllers through the MiOS app.
  • Fixed an issue where Meshbots could not be saved in the Mios app.
  • Translation corrections have been applied related to Private Label.
  • Fixed the missing resident account selection for installer accounts in the MiOS app.
  • Fixed app crash when editing a meshbot created incorrectly from the iOS App.
  • Fixed issue preventing the creation of Meshbots with Eltako ESB62NP-IP Shading actuator in the MiOS App.
  • Fixed an issue preventing the creation of meshbots using the Eltako EUD62NPN-IP/110-240V in the MiOS app.
  • On/Off button for Eltako ESR62NP-IP/110-240V is now available in the MiOS App’s Devices View.
  • Fixed issue preventing the Eltako ESR62NP-IP/110-240V impulse switch from being used in Meshbots Device Actions.
  • On the Devices View in the MiOS App, the On/Off button for the Eltako ESR62PF-IP/110-240V can now be used to control the device.
  • Fixed an issue preventing the Eltako ESR62PF-IP/110-240V from being used in Meshbot Device Actions within the MiOS App.
  • The On/Off button for the Eltako Dimmer EUD62NPN-IP/110-240V is now hidden, displaying only the dimmer slider.
  • The order of the “Up” and “Down” buttons for the Eltako ESB62NP-IP shading actuator has been corrected in the MiOS App.
  • Updated the MiOS App to display the correct icon for the Eltako ESB62NP-IP / 110-240V Shading actuator.
  • Fixed an issue where the dimmer couldn’t be set to 100% for the Eltako EUD62NPN-IP/110-240V.
  • Fixed an issue that was preventing the dashboard from loading successfully after exiting the camera stream.
  • Hue Lamps now display the correct OFF status when turned off in the app.
  • Fixed crash when selecting “Valid From” in Daily restrictions on MiOS.
  • New design implemented for MiOS app screens.
  • Timeline records in the MiOS App now display in the correct order.
  • Devices created by the Vacation Plugin now support “On/Off” buttons.
  • Fixed an issue with the dashboard displaying items incorrectly on smaller screens.
  • The dashboard now displays the complete list of devices.
  • Fixed issue where icons were missing for certain devices on the dashboard.
  • Fixed an issue where devices did not display on the dashboard when the app was opened.
  • Fixed a crash issue reported by Firebase Crashlytics.
  • Hue Lamps now correctly set dimmer values, with a minimum limit of 1.
  • Fixed the “Panel is Offline” error when saving restrictions on doorlock PIN codes in MiOS.
  • Fixed an issue where “No Cameras detected” was briefly displayed even when cameras were connected to the hub.
  • Camera preview on the “Devices” menu now displays quicker without the previous 4-5 second delay.
  • Fixed an issue where devices created by the Vacation Plugin were not available for use in Meshbots Actions.
Thank you for your continued support, and please let us know if you encounter any issues or have feedback!
Release notes link:
https://updates.ezlo.com/?filter_tag=mios
When will Android get Geofencing?
Hello @lmacvey
Android Geofencing is currently scheduled for release on April 17, 2025 . We appreciate your patience as we finalize this feature.
Please check Geofencing status for more details.
