Hello Richard,
We are sorry to hear you’re running into this issue. As you mentioned the default LMDB map size is in fact 64KB which is in accordance with the table size at which you’re encountering this error. The map size can be adjusted from your environment setup when using the Lua wrapper for the LMDB.
According to the LMDB documentation an environment should be initialized as follows:
lmdb.
Environment
( path , map_size=10485760 , subdir=True , readonly=False , metasync=True , sync=True , map_async=False , mode=493 , create=True , readahead=True , writemap=False , meminit=True , max_readers=126 , max_dbs=0 , max_spare_txns=1 , lock=True )
where path is the directory whithin the file system where the database is to be allocated and map_size the max size in bytes that the database is allowed to grow to. By default this parameter is set to low to encourage a crash so that you can figure out a good size to work with.
To offer you further assistance, can you please provide a code snippet of the script that’s causing this error?
Regards,
Santiago Gutierrez
Customer Care
