We’ve released a new live update for Ezlo Linux firmware 2.0.30.2041.2 [production-142]
The highlights of this release are
improvements and fixes for Meshbots in Ezlogic (Scenes)
“Database is full” issue fix and other bugfixes
The new live update for Ezlo Linux firmware 2.0.29.2027.3 for Ezlo Plus and Ezlo Secure controllers contains:
[Scenes][Conditions] Modify when block for compareNumbers to use (item value) as right part of the comparison. (item vs item, typed expression vs item)
[Scenes] isDate: remove “time” field from weeks and yearWeeks
[Scenes][Conditions] Modify when block for all item-based events to use (item value) as a right part of the comparison. (item vs item, typed expression vs item)
[Scenes] Implement isDeviceState
Getting the “database is full” error makes firmware not working
[http module] http.request() cannot pass certificate
@Max Just to reiterate, I too am not generally seeing automatic updates. I hope that shortly we will really need a better way to manage updates and that manually restarting each controller to take up an update will not be acceptable. What else have you got?
Auto update should work without interactions with a hub. A manual restart is a kind of troubleshooting step.
In order to investigate it in more detail, could you provide me the SNs of your hubs that weren’t updated in PM?
October 2022 Ezlo released a production version of firmware for the ezlo plus. The version number is 2.0.32.2097.3. How do I get the controller to update? I have tried to reboot the controller to get the update but that doesn’t seem to work.Thanks in advance for any help provided.
