If you have a moment, can you let me know what contact sensors you are using and roughly how much you paid (and even where you got them). All I found was one on this list:
I use fibaro door/window sensors on all my doors… they don’t really fall into the low cost category though at ?40(GBP) each from vesternet. They do work well though, never really had a problem with them.
There’s a post on here somewhere from someone who used a string of ‘normal’ window sensors wired in series and connected to a fibaro binary sensor to give a cheaper way to cover a bank of windows.
I don’t know who, if anyone, has access to alter the Wiki.
By “contact sensors” I presume you mean things like door/window sensors. Almost any Z-Wave door/window sensor will work with Vera. I can’t think of any that don’t work. If there are any, they will be a multisensor type where they not only have a door/window sensor but also temperature or light level reporting.
There are many other -Wave sensors available as well.
With the release of the Vera Plus which has Zigbee support, there will likely be a few Zigbee door/window sensors that also work with Vera. But it is too early to tell which ones do and do not work. Zigbee devices are not assured to work with Vera as there are many Zigbee protocol categories and proprietary implementations that Vera does not/will not support.
Zigbee sensors are typically more compact than the Z-Wave counter parts and are sometimes far less expensive. At this time, the only Zigbee door/window sensor known to work with Vera Plus is the NYCE NCZ-3011-HA ZigBee Door/Window Sensor. But that list will probably grow in time.
I have the GE/Quirky Tripper Door/Window sensor working with VeraPlus. The Tripper is very reasonably priced, uses a cheap 2032 battery and is relatively small and attractive. It is a Zigbee device. One downside is that it doesn’t report battery level.
[quote=“Z-Waver, post:3, topic:191279”]I don’t know who, if anyone, has access to alter the Wiki.
[quote=“rbakley, post:4, topic:191279”]I have the GE/Quirky Tripper Door/Window sensor working with VeraPlus. The Tripper is very reasonably priced, uses a cheap 2032 battery and is relatively small and attractive. It is a Zigbee device. One downside is that it doesn’t report battery level.
I bought two of these from Monoprice. On eBay right now for $20.99 or Amazon for $22.39
Monoprice 10795 Z-Wave Door and Window Sensor - NO LOGO
Both work fine. I bought the first one several months ago and it was fine on my Vera Lite. I bought another and both have been on my Vera Plus since I got it and both are working good. There is two screws inside the contact if you want to use a regular contact from an alarm system.
[quote=“jbfoster, post:7, topic:191279”]I bought two of these from Monoprice. On eBay right now for $20.99 or Amazon for $22.39
[quote=“VeraDad, post:8, topic:191279”][quote=“jbfoster, post:7, topic:191279”]I bought two of these from Monoprice. On eBay right now for $20.99 or Amazon for $22.39
Has anyone had any luck / experience with GoControl sensors?
It seems like the cost per sensor is pretty good if you buy them in one of these kits, plus you get the motion sensor or motion sensor and alarm for just a bit more:
2 contact sensors and 1 motion sensor for ~$43
(GoControl WNK01-21KIT Z-Wave Essentials Wink Enabled Security Kit)
Amazon Link: http://goo.gl/64885T
[quote=“VeraDad”]Has anyone had any luck / experience with GoControl sensors?
Thanks for all the help![/quote]
I got a two pack and motion. When I first bought the package the Vera saw the door sensors as motion. Since then there was since a firmware update and they now work as intended. They are kind of a pain to pair at first, but they work well. Additionally the motion sensor appears to be the same internals as the monoprice. However, the Vera doesn’t show the temperature sensor.
Also you can sometimes find these sets on clearance at home depot.
[quote=“MLeBaugh, post:11, topic:191279”][quote=“VeraDad”]Has anyone had any luck / experience with GoControl sensors?
Sent from my XT1096 using Tapatalk[/quote]
Thank you MLeBaugh! Did you get this exact GoControl set?
[quote=“VeraDad”][quote=“MLeBaugh, post:11, topic:191279”][quote=“VeraDad”]Has anyone had any luck / experience with GoControl sensors?
Thank you MLeBaugh! Did you get this exact GoControl set?[/quote]
Yup, the exact set from Amazon. Shows the "you purchased this item… " after clicking your link.
Very cool. You’ve gotta love Amazon… of course it’s a little annoying when they keep asking me if I want to buy more Kleenex.
Do you happen to know (or can you measure) the dimensions of the magnet part? I have a double slide window (both sides open) and I want to make sure it would be slim enough to bit between the two windows on the back pane when opened.
I’d offer to measure them for you, but the locations I have them in is odd and I didn’t use the stock magnets and don’t know where they are.
One is on my fence outside, I have a large magnet attached as the tripper since the wood is very warped and doesn’t line up. The other is on a set of windows with a wired Reed switch so I can watch both windows with one sensor. I used the magnets from the reed switches for both…
[quote=“MLeBaugh, post:15, topic:191279”]I’d offer to measure them for you, but the locations I have them in is odd and I didn’t use the stock magnets and don’t know where they are.
NM found them in the reed switch bag. 1/2"[/quote]
Thank you again! Super helpful!
So how did you get yours to work outside? Did you use them as is or do something special to protect it?
I just used it as is. I doubt it will last forever. It’s been out there for about 6 months snow and rain. The sensor itself sits at the front of the case unlike others so it would have to get really wet to get into the electronics. Plus the case itself sits fairly snug. If anything the front led hole is the weak point, some silicone should solve that… I’ll add that to the to do list.
It looks like the older model. The new one is called “Iris Contact Sensor” model# 3320-L. The older one is called “Iris Indoor Window and Door Sensor.” They also look different in the pictures.
