Battery Powered devices
- Low Battery - Any battery-operated device that has the battery <= 20%
- Very Low Battery - Any battery-operated device that has the battery <= 10%
Security Sensors
Smoke Sensor - Smoke Detected
Smoke Sensor - Smoke No longer Detected
- Leak Sensor - Water Leak Detected
- Leak Sensor - Water Leak No longer Detected
- CO Sensor - Carbon Monoxide Detected
- CO Sensor - Carbon Monoxide No longer Detected
- Heat Sensor - Overheat Detected
- Heat Sensor - Under Heat Detected
- Sensor - Tampered
- Sensor - No Longer Tampered
- Contact (D/W) Sensor - Opened
- Contact (D/W) Sensor - Closed
- Motion Sensor - Motion Detected
- Motion Sensor - Motion No Longer Detected
- Glass Break Sensor - Glass Break Detected
Door Locks
- Locked
- Unlocked
- Lock Button Pressed
- PIN Code Added to Device
- Fails to Operate
- Wrong PIN Code Used
- PIN Code Removed
- All PIN Codes Removed
- Impact detected
Garage Doors
- Opened
- Closed
Thermostat
- Turned Off
- Set to Heat Mode
- Set to Cool Mode
- Set to Auto Mode
Doorbell
- Rings
Water Valves
- Water Valve Opened
- Water Valve Closed
Siren (Ezlo Secure Built-in)
- Active
- Inactive
Devices (General)
- Hardware Failure Detected
- Hardware Status OK
- Software Failure Detected
- Software Status OK
