Hi Richard,
Thank you for a great plugin. I purchased 2 licenses for Vera Alerts within a few hours from each other.
When i enter the second license code and click Verify it says “successful” but even after save and reboot it still shows “You have 1 license, which allows for 2 active profiles.”
I ordered a Vera Plus to replace Lite. When it arrives, I plan to go through the upgrade/transfer process. I am aware that my PLC and VA licenses are tied to the device and do not mind at all licensing them for the new device.
For clarification, I presume I go through the transfer process where all the devices/apps/plug-ins will be installed onto the Plus, once fully up on the Plus, I would license the plug ins?
You will need to upgrade the Plugins as well, after you migrate, if you are going from UI5 yo UI7.
Otherwise you will migrate the UI5 version of the plugins … which will not work on UI7.
Yes you will need a new license. If you have more than one license I have a significant savings, buy your first upgrade license and email me with the OLD and NEW vera Serial #
Good inf? Richard. I hadn’t thought of that. Much like snovvman, I will be happy to just relicense. As you once said, it is like buying you a beer and I often wish i could do that in person.
[quote=“RichardTSchaefer, post:88, topic:179809”]You will need to upgrade the Plugins as well, after you migrate, if you are going from UI5 yo UI7.
Yes you will need a new license. If you have more than one license I have a significant savings, buy your first upgrade license and email me with the OLD and NEW vera Serial #[/quote]
Email inbound to you with my old and new serial numbers…
I am going from Vera Lite UI7 to Vera Plus UI7.
This is the order that I will be following:
Setup Vera Plus (basic network, access, etc.)
Backup Vera Lite
Put Vera Lite into Controller Shift mode
Put Vera Plus into Copy ZWave network master controller mode
At this point, I presume all the settings, scenes, devices, device settings, apps, app settings will be transferred over from Lite to Plus. I’m hoping that all the Vera Alert and PLC settings and customizations will be there.
I assume I would apply the new licenses to Vera Plus after everything is up and running?
But if I am going from UI7 to UI7 (and I am already on 6.37 on Vera Lite), I assume the upgrade will install the correct version?[/quote]
You click the upgrade button and it will install the latest version on both the front end and back end. Doing any kind of upgrade from one vera to another doesn’t make a full clone of the unit, the firmwares on the unit are also different as with the z-wave chip. To insure everything in the background gets installed and updated to the latest you click the upgrade button in the app section anyways even if it shows you have the latest version number.
I am unbale to buy-register a licence for vera alerts , I just did PLEG , that worked fine , but when I click register on the vera-alerts “editor option” nothing happends, I get a blanc page.
The question above is for my new vera+
When I upgrade my older vera3 to UI7 ( has now UI5) with 2 PLEG licences and 2 vera alert licences, can I still use the licences for the Vera 3 after upgrade, or do I have to buy new licences for my vera 3 as well?
The same license works with UI5 and UI7 for a Vera 3.
But a Vera Plus will need a license.
Whenever you change the Vera Firmware from UI5 to UI7 (or back to UI5) you must upgrade the software to get the correct version specific software.
When you upgrade a Vera 3 Firmware from UI5 to UI7, this does not upgrade the Vera Alerts software from UI5 to UI7, thats why the upgrade is needed.
OK , cool. I will upgrade my vera 3 next week or so.
But for my vera plus , I am unable to register-Pay a new licence. when I click on the tab “register”, all stays blanc… obh … wait… disregards…
AH … I see , since I am working remotely on not on the same LAN that is the issue. When I logged on via teamviewer on a computer at home and than locally on the vera edge it works fine.
