Hi! First post! ![]()
Just refitted the whole condo with a mix of Evolve switches and 3 Leviton 4 button scene controllers (the ones with local load control) don’t remember the exact model. Running Vera 3. Had some hassle adding the scene controllers, but read the instructions about the “programming mode” and after that all seems running well. However, I created some scenes, in some cases they include regular switches and dimmers to be set to a certain level. When I run the scenes off Vera3, all is great and work as supposed to. Obviously the same thing off the iPhone. However, after assigning scenes to buttons, I get strange behaviour:
- In case of a scene where a light is to get turned on on one switch, and dimmer to be set to full, I only get the light to get to turn on, no reaction from the dimmer.
- In other case, where I do “house off” the other controller would turn all the lights but one off.
Generally the behaviour is not very consistent. Seems like to toggle scene on, I have to press once, to toggle off, I have to double tap. Not sure exactly what I’m doing wrong. Pretty certain that scenes are fine, since I can tell vera to run it and it’s ok.
Are there any detailed instructions about Leviton and vera scenes? Anything I should read? Some of the stuff is confusing on the on and off state of the scene in Leviton etc.
Could someone point me in the right direction?
