[quote=“jsed, post:12, topic:170832”]One thing to remember- if the Leviton scene controllers are controlling anything other than Leviton devices in one scene (mixed manufacturers- not sure about Cooper Aspire), the scene buttons must be set to ON/OFF only. For whatever reason- perhaps b/c of the Leviton patent on 2 way communication, scene dimming will cause the operation (button programming) to fail.
For example:
If you assign three Leviton devices to a Lev Scene Controller Button #1, you can dim or on/off. If you assign 2 Evolve controllers to Button #2 you will need to be sure its On/OFF.[/quote]
Among other issues on general reliability, and recently losing local load control (I’ve found multiple threads on each), i’m also having what i think you are describing here - as a problem in one of my scenes.
one button on my controller is set to turn on all the lights in my kitchen, via a scene i created. One light is the local load, one is a GE switch, and the last is a Leviton Dimmer Switch.
The scene executes perfectly from MiOS, but if i try to invoke it with the controller, only the local load and the GE switch will turn on…NOT the Leviton Dimmer. Ironically, if i have them all on (activated from MiOS, then when i toggle the switch, they DO all turn off).
I’m not sure by what you mean to setup the button on the controller “you will need to be sure its On/OFF” if it’s a mixed environment? can you help?
thanks.
