THIS PLUGIN HAS BEEN WITHDRAWN FROM DISTRIBUTION
Version History:
v0.56 - (Version ID: 35221) December 11, 2017
– fixed - fixes for openLuup support of smoke/co sensors
v0.55 - (Version ID: 35191) December 9, 2017
– fixed - various fixes to json files for openLuup support
v0.54 - (Version ID: 35191) December 8, 2017
– fixed - Wink API changes caused connection failure under openLuup
– fixed - wrong device type for Tunable White devices
v0.51 - (Version ID: 34946) November 7, 2017
– fixed - various fixes for SHADE device
v0.50 - (Version ID: 34601) October 4, 2017
– fixed - support for Home Collections ceiling fans
– Fixed - various minor bugfixes
v0.48 - (Version ID: 34496) September 13, 2017
– Added - support for dimmer SetStepDelta, StepUp and StepDown actions
v0.46 - (Version ID: 34407) September 5, 2017
– Added - support for SHADE devices
– Added - support for “Door / Window Sensor” devices (IE: Fibaro)
– Added - support for linked service lock devices (IE: August Lock)
– Added - support for fan devices (IE: Home collections gardinier ceiling fan)
v0.24 - (Version ID: 32942) January 16, 2017
– Fixed - implementation for ToggleState action
– syncronize released app marketplace version
v0.23d11 - January 15, 2017 (manual update only)
– Fixed - plugin files md5 sums not updated
– Fixed - vera displays “can’t detect device” regardless of startup status
– Fixed - POLL client mode did not properly disable pubnub subscriptions
– Fixed - instances of plugins originally installed from APP Marketplace experienced LuaUPnP reload loop
** NOTE: Once the plugin installation is updated, the system will do an additional one or two restart loops before resuming normal operation.
v0.23d6 - December 11, 2016 (manual update only)
– Removed - depecrated code for local control/rooting of a wink hub (pre firmware 2.46)
– fixed - HTTPS fallback did not use the correct HTTP User-Agent string
– Changed - oAuth token validity reduced to 7 days - Automatic token refresh when validity period expires
– fixed - AAU API changes prevented AAU validation
– Added - Allow HTTPS fallback to detect invalidated oAuth tokens
– Changed - force oAuth token refresh during plugin version change
– Fixed - Wink Relay sensor data not retreived
v0.22b14 - December 2, 2016 (manual update only)
– Fixed - AAU Authentication malformed in some circumstances
v0.22b13 - November 14, 2016 (manual update only)
– Added - Support for leakSMART sensor
– Added - Support for leakSMART valve
– Fixed - AAU validation on Wink Hub V2 causes Luup restart
– Changed - force AAU validation to use HTTPS fallback for Wink Hub V2
– Added - 10 second timeout to HTTPS Fallback routine
v0.22b10 - November 13, 2016 (manual update only)
– changed - local control command response changes prevent detecting AAU authorization status
– fixed - under certain conditions HTTPS fallback can cause the plugin to crash
v0.22b8 - November 11, 2016 (manual update only)
– updated - api backend url changed
– added - HTTPS fallback to using curl if the lua socket library fails to return data from an HTTPS call
v0.22b6 - September 28, 2016 (manual update only)
– fixed - Wink Relay devices not properly initialized/processed, preventing use of multiple devices.
v0.22b5 - September 24, 2016 (manual update only)
– added - basic support for camera devices (ie: Dropcam / Nest cam) - basic recording control and motion detection (if supported by camera)
v0.22b4 - September 23, 2016 (manual update only)
– changes due to Wink API changes
– fixed - expired AAU token caused authorization loop
v0.22b3 - July 3, 2016 (manual update only)
– fixed - AAU token not retrieved on beta firmware 7.0.15
– added - handling of expired AAU token
v0.22b1 - April 2, 2016 (manual update only)
– fixed - AAU Event proxy would cause reboot loop on VeraPlus
– fixed - sending specific commands to the AAU port of a Hub/Relay generated a “could not update device” warning
v0.22 - March 19, 2016 (Available from App Marketplace)
v0.21.rc9b - March 9, 2016 (manual update only)
– fixed - fixed corrupted UI5 json file
– fixed - md5sums updated
– fixed - md5sums were calculated before UI specific files were updated
v0.21.rc9 - March 7, 2016 (manual update only)
– changed - removed obsolete LOCAL and COMBINED API modes
v0.21.rc7 - February 8, 2016 (manual update only)
– fixed - regression in rc6 - Temperature Mode not detected and defaults to “C”
v0.21.rc6 - February 7, 2016 (manual update only) - RELEASE NOTES
– added - updates for Wink API Changes for hub firmware 02.49
– added - Support for LOCAL CONTROL implemented in Wink Hub Firmware 02.49
v0.21.rc3 - January 30, 2016 (manual update only)
– added - initial support for openluup
– added - initial support for AltUI
v0.21.rc1 - January 17, 2016 (manual update only)
– changed file management to reduce installed file count
v0.20.42 - January 17, 2016 (manual update only)
– added support for Ring Video Doorbell
– added support for binary switch and light bulb devices that are reported as a linked service (ie: iHome SP5)
– fixed - device processing for Wink Relay with no associated sensor_pod
– fixed - UI7 scene controller button display bug
v0.20.31 - December 12, 2015 (manual update only)
– added last update checking for switch/dimmer devices
– fixed logic error in processing scene controller data
– changed sensor pod detection to avoid extraneous remote api requests
– changes to support AAU Event Stream (local notifications for wink firmware v2.36+)
– fixed AAU control prevents pico/CBR remote updates
– fixed type in RGBW device definition
– added AAU Event Stream Proxy daemon (local notification receiver for wink AAU enabled firmware)
v0.20.24 - December 3, 2015 (manual update only)
– fixed bug in group device member status processing due to changes in data returned by Wink API.
– added automatic group member device polling when status data returned by the Wink API does not include member device status.
– added last update checking due to out-of-order notifications sent by the PubNub notification server.
v0.20.20 - November 29, 2015 (manual update only)
v0.20.13 - November 24, 2015 (manual update only)
v0.20.12 - November 23, 2015 (manual update only)
– Add UI7 support for Color Changeable light bulbs
(on/off/dim/color for RGBW and on/off/dim/color temperature for Tunable White bulbs)
– Add partial UI5 support for Color Changeable light bulbs
(on/off/dim for RGBW and on/off/dim/color temperature presets for Tunable White bulbs)
v0.20.3 - October 28, 2015 (manual update only)
– fixes crash when processing
v0.20 - October 27, 2015
– general availability release of all updates since v0.19
v0.19dev23 - September 26, 2015 (Manual update only)
- fixed - plugin crashes when processing group devices (see HERE for details)
v0.19dev22 - September 16, 2015 (Manual update only)
- added - support for Lutron Connected Bulb Remote (see HERE for details)
v0.19dev19 - September 8, 2015 (Manual update only)
- added - icon for Rheem Econet Water Heaters
- added - option to create Vera devices for Temperature and Humidity devices on Wink Relay and Quirky Spotter
- added - support for Quirky+GE Tapt Smart Switch (see HERE for details)
v0.19dev15 - September 1, 2015 (Manual update only - EXPERIMENTAL)
- add status/control for Rheem Econet Water Heaters
- fixed error in UI5 json file for thermostats
v0.19dev14 - August 29, 2015 (Manual update only - EXPERIMENTAL)
- fixed - Nimbus dial configuration json not correctly encoded
v0.19dev13 - August 28, 2015 (Manual update only - EXPERIMENTAL)
- fixed - Pico remote javascript error when no target devices (REMOTE mode)
- fixed - Nimbus dial configuration parameters not passed as documented
v0.19dev11 - August 28, 2015 (Manual update only - EXPERIMENTAL)
- add control of dial pointer position and backlight brightness
v0.19dev10 - August 27, 2015 (App Marketplace OR manual install)
– add Nimbus dial update support - see HERE for details
v0.19 - August 12, 2015 (App Marketplace OR manual install)
– general availability release of all updates since v0.18
v0.18b101 - August 12, 2015 (manual update only)
– fixed - UI5 settings - page layout corrected for addition of “shortcuts” option
– fixed - UI5 settings - device summary display not formatted correctly
v0.18b100 - August 9, 2015 (manual update only)
– added - initial support for Wink Shortcuts
see HERE for details and changed file list.
v0.18b99 - August 9, 2015 (manual update only)
– added - limited support for control/status display from mobile apps that use generic serviceid for unknown device support
– added - initial AAU support (upcoming wink native localcontrol interface)
– added - local device control of group devices if Wink API command fails (using Local_Api or AAU if available)
– changed - tweaks to load level calculation for dimmer devices
– added - configured wink device summary on device settings
– changed - no longer suppress vera device creation for remote pico with no members
see HERE for changed file list.
v0.18b91 - July 28, 2015 (manual update only)
– Fixed - REMOTE/COMBINED MODE - plugin would not process devices properly if a Wink Hub/Wink Relay was not attached to the Wink Account
v0.18b90 - July 28, 2015 (manual update only)
– Updated - local_api to v0.38
– Changed - handling of possible api changes to Power Pivot
– ADDED - Ability to use a Pico remote as a scene controller when using LOCAL api mode
v0.18b86 - July 22, 2015 (manual update only)
– fixed - (verified) local api - fixed device processing of new format device id for newly installed zigbee devices on firmware 01.01
v0.18b84 - July 22, 2015 (manual update only)
– fixed - (verified) plugin crashs due to changes in the subscription data for device state notifications
v0.18b82 - July 21, 2015 (manual update only)
– fixed - additional plugin crash due to changes in the subscription data for device state notifications
– fixed - obscure bug that caused plugin to crash if an action was requested before the plugin had completed initializing child devices
v0.18b81 - July 20, 2015 (manual update only)
– fixed - plugin crash due to changes in the subscription data for device state notifications
v0.18b79 - July 19, 2015 (manual update only)
– updated - local_api updated to v0.36
– fixes - local_api - When adding a new Cree bulb, it is flagged by the Wink APP as a switch instead of a dimmer
– fixes - local_api - certain conditions would cause the powered state of a dimmer device to update incorrectly
v0.18b78 - July 17, 2015 (manual update only)
– fixes - typo in v0.18b77 that caused the plugin to fail to load
v0.18b77 - July 17, 2015 (manual update only)
– fixes - dimmable light state not always updated correctly
– added - SwitchPower1-Status variable update for dimmable light and group devices
** NOTE ** - If you are upgrading from v0.17b75, you only need to upload L_Wink_Hub1.lua to your Vera
v0.18b75 - July 3, 2015 (manual update only)
– fixes accidental regression of auto-update code for Local API on rooted Wink Hub
– fixes device processing misidentified devices under certain circumstances for Local API on rooted Wink Hub
– fixes support for multiple Wink Hubs on the local network (local API) - would only process the first Hub found
– fixes device definition/state not processed properly due to Wink API changes
– fixes authorization token expiry handling
– fixes dimmable light device state gets out of sync
– adds automatic token refresh/reauthorization on authorization failure
– fixes device definition/state not processed properly due to Wink API changes with hub firmware 01.01
– fixes Wink Relay Smart Buttons would not reset once tripped
v0.18b42 - April 28, 2015 (manual update only)
– General availability release combining all updates since v0.18b12
– adds UI7 support for door lock basic functions (lock/unlock)
– adds support for association control for Pico Remotes (REMOTE API only) (Add/Remove devices associated with a remote only)
v0.18b12 - April 22, 2015 (manual update only)
– General availability release combining all updates since v0.17
v0.18 - April 21, 2015
– fixed - MYQ garage door controllers now work with UI7
– added - Garage Door Controller extended to any device that is reported as a “garage_door” by the Wink API
– added - fault notification for garage door controllers.
v0.17b70 - April 20, 2015 (Manual installation only)
v0.17 - March 9, 2015
v0.16 - March 4, 2015
v0.15b149 - February 25, 2015 (not available in the App Marketplace)
v0.15b140 - February 22, 2015 (not available in the App Marketplace)
v0.15b120 - February 18, 2015 (not available in the App Marketplace)
v0.15b115 - February 18, 2015 (not available in the App Marketplace)
v0.15 - February 5, 2015
v0.13 - January 27, 2015
v0.12 - January 25, 2015
v0.11 - January 14, 2015
v0.10 - January 12, 2015
V0.9 - January 12, 2015
Initial public release
*** NOTE 1 *** If you are updating an existing installation, you MUST reload the LuaUPnP engine one additional time after the plugin has downloaded and installed. (UI5: click on reload button on dashboard - UI7: go to “Wink Hub” setup page, click on “Advanced”, click on “New service”, click on “Reload Engine”)
*** NOTE 2 *** Once the plugin has updated/installed, you MUST refresh your browser using F5 or CTRL-F5.
