v0.22b10 - November 13, 2016 (manual update only)
– changed - local control command response changes prevent detecting AAU authorization status
– fixed - under certain conditions HTTPS fallback can cause the plugin to crash
v0.22b13 - November 14, 2016 (manual update only)
– Added - Support for leakSMART sensor
– Added - Support for leakSMART valve
– Fixed - AAU validation on Wink Hub V2 causes Luup restart
– Changed - force AAU validation to use HTTPS fallback for Wink Hub V2
– Added - 10 second timeout to HTTPS Fallback routine
v0.22b14 - December 2, 2016 (manual update only)
– Fixed - AAU Authentication malformed in some circumstances
v0.23d6 - December 11, 2016 (manual update only)
– Removed - depecrated code for local control/rooting of a wink hub (pre firmware 2.46)
– fixed - HTTPS fallback did not use the correct HTTP User-Agent string
– Changed - oAuth token validity reduced to 7 days - Automatic token refresh when validity period expires
– fixed - AAU API changes prevented AAU validation
– Added - Allow HTTPS fallback to detect invalidated oAuth tokens
– Changed - force oAuth token refresh during plugin version change
– Fixed - Wink Relay sensor data not retreived
v0.23d11 - January 15, 2017 (manual update only)
– Fixed - plugin files md5 sums not updated
– Fixed - vera displays “can’t detect device” regardless of startup status
– Fixed - POLL client mode did not properly disable pubnub subscriptions
– Fixed - instances of plugins originally installed from APP Marketplace experienced LuaUPnP reload loop
** NOTE: Once the plugin installation is updated, the system will do an additional one or two restart loops before resuming normal operation.
v0.24 - January 16, 2017 (Pending App Marketplace approval)
– Fixed - implementation for ToggleState action
– syncronize released app marketplace version
v0.46 - (Version ID: 34407) September 5, 2017
– Added - support for SHADE devices
– Added - support for “Door / Window Sensor” devices (IE: Fibaro)
– Added - support for linked service lock devices (IE: August Lock)
– Added - support for fan devices (IE: Home collections gardinier ceiling fan)
– Fixed - various minor bugfixes
v0.56 - (Version ID: 35221) December 11, 2017
– fixed - fixes for openLuup support of smoke/co sensors
v0.55 - (Version ID: 35191) December 9, 2017
– fixed - various fixes to json files for openLuup support
v0.54 - (Version ID: 35191) December 8, 2017
– fixed - Wink API changes caused connection failure under openLuup
– fixed - wrong device type for Tunable White devices
