[quote=“Sammy2, post:52, topic:185577”][quote=“integlikewhoa, post:51, topic:185577”][quote=“Sammy2, post:50, topic:185577”]This is fantastic information! Thank you!!
I will look into which board I have, maybe tonight, so I can determine which way to go with this. The pool was in when we bought the house in 2014 but we are remodeling the back yard now and would like to have it controlled with the Vera Plus and include the pool in that control…[/quote]
Remember iAqualink will not give you control via VERA. So that is a different path as of now and the last few years. Autelis is what is needed to make the vera connection and that system has two different setups depending on if you have a PDA now or not.
If your running anything other then a PDA (one touch or aqualink) then you’ll need this one.
If you want the iAqualink Web UI control and setup and phone or tablet apps, plus you want vera control then you currently would need to buy both systems which would total around 795.00 ish combined.[/quote]
PDA as in Personal Data Assistant?
Nope, never had one of those. I jumped right to smart phone with the original G1 Google phone came out, and even Helio before that…
I have a wall mounted RS controller so I guess I need the basic one.
Can Vera Plus control the autelis via WiFi, Bluetooth or Z-Wave?? Not sure why I need the iAqualink if that is the case.[/quote]
Vera uses connects Via plugin and IP address of the Autelis unit which has a hardwired network connection and a wire connected to your rs panel.
http://forum.micasaverde.com/index.php/topic,30275.0.html
iAqualink is a the brain of the pool controller that allows setup and control via a web browser. Right now you do this via the RS controller. iAqualink adds some new features but maybe none that you will use or need. Autelis simulates a pool keypad and allows you to make changes and turn things on and off. It doesn’t replace the controller (rs touch or iAqualink) but runs along side it like a generic remote. It allows web access (they don’t have any app that I know of) via a web browser and allows you to turn things on off and make changes as if you were using a remote from anywhere in the world via the internet. So if you were buying iAqualink just to turn on the spa while you were gone then you can do this for around 270.00 vs. the whole iAqualink kit at 525.00. But the kit is more then just the internet part it’s also the updated board.
iaqualink can connect via wired or wireless Autelis has wired only and you would need a wireless bridge to make it wireless if needed. Version 1.0 was very picky on the wifi network type and security it used to connect. I think 2.0 has gotten better, but 1.0 was “G” and not passkey with only one kind of encryption. I found the hard way after alot of internet connection problems in the beginning.
I would probley just get the Autelis and call it done until you want to upgrade a pump valves or something else that requires the new board. Even then you can choose new rev. board only or iAqualink at that time. I did end up using JVA controller to stop my motorized valves in the middle. I was unable to do this with my older revision before. I don’t have a variable speed pump but figured when mine goes out that will probley be next which it can now be controlled.
Autelis will give you more bang for your buck for around 270 plus wifi adapter you can have internet control of your pool and vera control also which sounds like all you need. Contact Autelis after you find your revision info and before you buy anything to make sure all works with what you have currently.
