Since this morning all my automation stopped. Upon checking, it seems my vera3 is offline (not reachable via apps or webui), but via ssh I can login to the system.
If I tail the /var/log.Init-LuaUPnP logfile, I get the following:
ERROR: failed to get auth token from: vera-us-oem-authd11.mios.com, curl/http: 6/0, is backup: 1
ERROR: failed to get auth token from: vera-us-oem-authd12.mios.com, curl/http: 6/0, is backup: 0
Trying to open these in the browser fails also. Changing the URL to https kinda works (in the browser).
It seems that EZLO is blocking all http traffic to the mios.com endpoints causing my Vera3 to be kinda worthless
Any other Vera3 “die hard” users that have this issue?
Will do a check and provide a solution. Non SSL is not ideal but if we won’t find the culprit I will enable non SSL data to be allowed if coming from the controller/gateway.
It seemed strange that also vera alerts was not working anymore, so I dug a little deeper.
Apparently the DNS servers were gone or not responding anymore which caused all calls to aliases to simply fail. After adding new DNS servers, everything started working again and I can confirm that the vera 3 tries to connect to https endpoints
First determine if you have the same issue. Log in to your vera3 through ssh.
Then simply try a ping to google.com:
root@MiOS_Serial:~# ping google.com
ping: bad address 'google.com'
My fix: (be careful, you might break stuff…)
Login with root to your vera3 through ssh.
Execute “uci show dhcp” and inspect the “dhcp.@dnsmasq[0].server” entry (was missing in my config)
Add DNS servers to this variable and restart dnsmasq:
