The easiest way to install plugin to emulate devices is quite simple and requires 2 requests.
First we need to execute: { "method": "hub.software.update.plan", "id": "_ID_", "params": { "operation": "install", "type": "plugin", "id": "test_plugin" } }
The result of the previous request should be inserted into this request: { "method": "hub.software.update.execute", "id": "_ID_", "params": { "actions": [ <Result of previous command> ] } }
Thats all, now we have installed virtual devices on your Ezlo Plus/Ezlo Secure hub.
Also see here the Vera to Ezlo Bridge plugin, if you want to create virtual devices on the Ezlo Plus hub that actually control real devices on your Vera hub.
Thanks for the reply. I saw that post elsewhere and I should have been more clear. I just got a Production US Ezlo Plus. I took a picture of the bottom of the hub, don’t see anything that resembles a password.
I have Serial, Mac, Wifi, SSID, IC, FCC ID and DSK. Can I use one of those?
Is this thread for Developers only? Because nothing said so far makes sense to me as a Vera user, who’s accustomed to plugins easily making virtual devices like Switchboard.
Presumably ezlo controllers will become that simple, too? And why is there a Vote button on this Topic?
With Vera controllers we had plugins that enhanced the features of different devices or allowed for features that were otherwise unavailable, sometimes they were created by us and sometimes by third parties. The new controllers come with some of these plugins as native but we are currently in the process of integrating lots of devices and features. As for the vote button, that is a feature on the forum to up vote post that users find the most relevant.
What happens if you don’t attempt to register for a new account in the Online Api Tool website and instead just try to login with your existing Vera user account username and password?
I just created a brand new Vera user account for something to add a new controller and I was able to just login to the Online Api Tool Web page with those new login details.
We are working to resolve the issues with eZLO VOI and therefore the possibility to add Virtual devices.
For now, we strongly recommend following the guide shared by CW-KID
Please keep in mind that you will need to create virtual devices that can be controlled through Alexa like Smart Switches and Light Bulbs.
I will also create a support ticket so we can have access to your unit and test with your controller, that way we could replicate it, as it doesn’t on our side.
