Sorry if this has been asked and answered, I’ve searched tons of messages on “associations” and “groups” but can’t find any basic step-by-step instructions, I hope someone can help me.
I have 3 devices that I want to associate in a group, so whenever one device in the group changes ALL devices in the group make the same change:
Wall Switch: Leviton DZ6HD-1BZ, Device ID #71
Lamp1 Module: Leviton VRPD3-1LW, Device ID #75
Lamp2 Module: Leviton VRPD3-1LW, Device ID #76
One each Device Settings page I changed “Automatically Configure” from “Use default values” to “Yes” per the note on Device Options page which reads “You must leave automatically configure on before this works”. Since “on” is not an actual setting, I assume this note means set the value to “Yes”.
I created Group ID 1 for each device, and identified the other members of the group, so for example on the Device Settings page:
ID71: Group ID: 1;Set to: 75,76
ID75: Group ID: 1;Set to: 71,76
ID76: Group ID: 1;Set to: 71,75
All of these devices support Command Class 133.
It doesn’t work, when I change the status (power level, on, off) of any one device in the group, none of the other devices in the group are notified and synch to it.
Ugh! Thanks much for that info, I’m pretty shocked - these are EXPENSIVE switches (around $50/switch, and I’m doing around 50 of them!), and their latest generation z-Wave Plus.
The lamp modules are older, I think I bought those 4 or 5 years ago for another house.
Oh well, I can do the same thing with scenes - it just would have made better sense to use Associations.
Well this is confusing, according to Leviton’s published info for this switch it DOES support Association (Group 1):
Now I’m twice as confused, does the device support Associations or not? And is it only Group 1 - I’d like to do Associations for double-tap which I think is (normally) Group 2?
Doh! You are right looks like it does support Association (it is instant status that is not going to work). Looks like they only support group 1 with a single tap (group 2 does not necessarily mean double tap each manufacture is different, some use Group 2 instead of Group 1).
What I have found (and what they don’t allow you to set in the parameters in the manual) is that zwave+ switches will not associate correctly to switches that are not zwave+ as they send out the commands encrypted (where non-zwave+ is unencrypted). Most of the other zwave+ devices I have seen to work around that limitation allow you to either set a parameter to have the association be “unsecure” or you have to include the switch in “unsecure” or “legacy” mode. Unfortunately Vera doesn’t let you specify that one way or another.
However it looks like your target devices are also zwave+ devices so things should work. They are all zwave+ right?
One thing I would try… exclude and re-include the switches and lamp modules to ensure all association data gets wiped. Try associating one wall switch to the other in group 1. That will help identify for sure that the wall switches (identical devices) are working with direct association.
It only supports Group 1. Attached is snippet from manual.
Which is wicked confusing. It says it is a lifeline group… but then says all status changes are communicated.
so basically, it may or may not work the statements seem a little contradictory. But if it is Lifeline only that isn’t going to do what you want in all likihood. That LIfeline thing is really only to associate back to Vera to get instant status.
That doesn’t work either. Though there is a hack in the thread to get something close to instant status (due to a bug in Vera not understanding hte difference between the Decor and RF+ lines)
It doesn’t look like the VRPD3-1LW units are z-wave plus (these are older modules, maybe 5 years old). I’ll try associating a pair of DZ6HD-1BZ switches in Group 1 and see if that works and report back.
Meanwhile, it looks like someone wrote the code to fully support these Leviton Decora z-wave switches for SmartThings, can this code be deployed on Vera?
PLEG will do the job OK, but this appears to be a common problem with Vera in not properly supporting Group Associations.
Just a query - you have Added Group 1 Device Options Tab?
Could you post a screen shot of the current group config such as this example?
[quote=“zedrally, post:10, topic:197634”]PLEG will do the job OK, but this appears to be a common problem with Vera in not properly supporting Group Associations.
Could you post a screen shot of the current group config such as this example?[/quote]
I no longer have the Group 1 associations in place (I deleted them), it was as I described in my first post above. I’ll set up a new association when I have time (probably this weekend), and can do a screen shot then.
I ran a test this morning, associating two Leviton DZ6HD-1BZ switches (both z-Wave Plus) in Association Group 1, it didn’t work.
The devices are:
ID 58: Dining - Art
ID 58: Dining - Table
Each of the device option pages is attached.
I coded both device ids on both Associations so for example when I was configuring Device 58 I associated it with Devices 56 AND 58. It wasn’t clear if I should ONLY associate 58 with 56, and 56 with 58. Also, on the Association page, there are free-form text boxes with these instructions:
The text boxes are only valid with devices that support multi-channel association. Type the endpoint(s) you want to be part of the association, separated by commas if there is more than one.
So does that mean I need to type in the device ids separated by commas IN ADDITION to selecting them with the checkboxes? It’s not very clear.
[quote=“MichaelCoffin, post:12, topic:197634”]So does that mean I need to type in the device ids separated by commas IN ADDITION to selecting them with the checkboxes? It’s not very clear.
-MC[/quote]
like everything with Group Associations it’s clear as muddy water.
What it refers to another point of confusion-Endpoints.
You will need to determine what the endpoint(s) of the Multi Channel device you are using are.
Generally this could be 1,2,3 etc unless the documentation states what they are and what they Node they control then you can only guess- far from ideal and extremely time consuming as you have now found out.
So in theory what you need to do is to select the Device you want to control from the Device (that is controlling) Options TAB and add the endpoint (1,2,3 etc) and save.
Good luck:)
Very very few devices support end points. You should have to mess with those.
All you need to do is check the box of the device you want target (associations work from source to target). You just need to select the target. If you want the association to work in both directions then do the same thing on the other device again using group 1 and target the original device.
I tried changing the associations so 56 only pointed to 58, and 58 only pointed to 56, in Group 1 - still no love, it just doesn’t work.
To add insult to injury, the VeraPlus keeps restarting now - reconfiguring EVERY device, never finishing, and restarting again - I’ll have to contact Tech Support tomorrow or Monday and have them take a look. I did add 7 more Leviton DZ6HD-1BZ switches today and the last one (Device #83) doesn’t look like it configured properly so that might be the cause of the looping Vera, but just to be sure I removed the associations I set up and deleted Device #83 (but it looks like Vera is still trying to configure it, and the “delete” must be queued to execute AFTER the configuration completes - and since that never happens there’s a Catch-22, the device still shows in the UI with a status of Purging Associations - I never did any associations with this switch however).
Usually group 1 is reserved for association with the controller.
For associations with other devices you should use other groups. You can check which group to use in the device’s manual, as various groups can have different functionality.
For example this is list of possible associations for one of my dimmers:
Group 1: Lifeline group (reserved for communication with the main controller), 1 node allowed.
Group 2: basic on/off (triggered at change of the input I1 and reflecting state of the output Q) up to 16 nodes
Group 3: start level change/stop level change (triggered at change of the input I1 state and reflecting its state) up to 16 nodes
Group 4: multilevel set (triggered at changes of state/value of the Flush Dimmer) up to 16 nodes
Group 5: basic on/off (triggered at change of the input I2 state and reflecting its state) up to 16 nodes.
Group 6: Notification report (triggered at change of the input I2 state and reflecting its state) up to 16 nodes.
Group 7: Binary sensor (triggered at change of the input I2 state and reflecting its state) up to 16 nodes.
Group 8: basic on/off (triggered at change of the input I3 state and reflecting its state) up to 16 nodes.
Group 9: notification report (triggered at change of the input I3 state and reflecting its state) up to 16 nodes.
Group 10: binary sensor report (triggered at change of the input I3 state and reflecting its state) up to 16 nodes.
Group 11: multilevel sensor report (triggered at change of temperature sensor) up to 16 nodes.
According to that, you should basically use Group 2 for passing ON/OFF command and Group 3 for passing the Dim Level.
If I read correct manual for your device (dimmer), it allows only one group (Group 1), up to 5 devices
This is a bit strange for me and I don’t have experience with that way of handling association groups. Make sure that your main controller is included in the group, as removing it from that group might be the cause for your issues.
This all just confirms what I said originally (and confirmed in the HomeSeer forums). This device does not support direct association, it only supports lifeline in group 1, which does do what you want. No other groups are supported on this device.
One more thought:
According to information from Vera interface, if you want to setup any groups “You must leave automatically configure on before this works”.
Maybe this is the trick? By default setting “Automaticaly configure” in device’s settings section is set to “use default behaviour”, so is better to change it for “Yes”.
See first post in thread, I tried setting this to “Yes” and also put it back to “default” - neither worked. I wish Vera would clarify this ambiguous language (i.e. should it be “default” or “yes”?).
