We’ve recently introduced a new group in the forum called “Ezlo Response team”
Ezlo Response Team is a public group and if you need help from someone specific just check the group to see the exact name and tag it in your post with @ . If you’re not sure which team member can help you with your inquiry you can even tag the entire Ezlo Response Team group with @ Ezlo_Response_Team.
