Is there a way using lua to retrieve the remaining space on a LAN drive.
Many thanks
Many thanks
Hello!.
You can use the following Lua code to print the remaining space information of your Vera controller on a .txt file on the /www/ directory.
local file = io.popen("df -h")
instr = file:read("*a")
file:close()
local file = io.open("/www/memory.txt", "w")
file:write(instr)
file:close()
You can access this file by typing the IP address of your Vera controller on the URL bar of your web browser followed by a forward slash and the name of the file.
Example:
HTTP://<YouVeraIPAddress>/memory.txt
It will look similar to this on your web browser.
Filesystem Size Used Available Use% Mounted on
rootfs 8.9M 5.7M 3.1M 65% /
/dev/root 9.8M 9.8M 0 100% /rom
tmpfs 61.9M 4.0M 57.9M 6% /tmp
/dev/mtdblock6 8.9M 5.7M 3.1M 65% /overlay
overlayfs:/overlay 8.9M 5.7M 3.1M 65% /
tmpfs 512.0K 0 512.0K 0% /dev
/dev/mtdblock10 64.8M 9.3M 55.4M 14% /storage
/dev/mtdblock10 64.8M 9.3M 55.4M 14% /etc/cmh-firmware
/dev/mtdblock10 64.8M 9.3M 55.4M 14% /etc/cmh-backup
/dev/mtdblock9 7.8M 7.8M 0 100% /mios
I am thinking that you could also copy this file to your LAN device via SFTP or SCP.
I don’t know how you could add this to the LUA code to automate it, to be honest. I am not that well-versed in coding.
local function getDiskSpace(path)
local function df()
local format = "(%S+)%s+(%d+)%s+(%d+)%s+(%d+)[^/]+(/%S+)"
local d = {}
local p = io.popen "df"
if p then
local df = p:read "*a"
p:close()
local n = tonumber
for f, b, u, a, m in df:gmatch(format) do
d[#d + 1] = {file = f, blocks = n(b), used = n(u), available = n(a), mounted = m}
return d
local dfinfo = {}
for _, d in ipairs(df()) do dfinfo[d.mounted] = d end
local x = dfinfo[path]
return {
total = x.available + x.used,
available = x.available,
percentage = (x.available /(x.available + x.used) * 100)
local disk = getDiskSpace('/overlay')
luup.log("Total: " .. tostring(disk.total))
luup.log("Available: " .. tostring(disk.available))
luup.log("Percentage: " .. tostring(disk.percentage))
just pass your path and you’re good to go
I’m using it to monitor the disk /overlay partition.
Wow. Thanks so much.
Is it possible to get the disk space on a LAN drive on the same network as my Vera hub?
Yes. Just pass the path. Get your paths running df command via ssh.
My network drive is running on a rpi on my LAN. How do I determine the path to put into your code? Thanks again.
Thank you so much!.
Is the drive mounted? I have mine setup this way, and I’m copying logs, data mine files and backups over there. It’s just under the output of a df command sent via ssh.
I just tried running your code on my Vera Edge and it does print to the log OK
luup_log:0: Total: 9600 <0x6e5b0520>
luup_log:0: Available: 3640 <0x6e5b0520>
luup_log:0: Percentage: 37.916666666667 <0x6e5b0520>
But then what can you do with it ?
Could you create a virtual device in Vera to display that information ?
Or enable Multi-System Reactor to see those values / variables ?
Yes you can. I’m pushing it every day to my SysMon device, where I’m reading it.
SysMon the plugin ?
Yep. I’m running a modified version of it.
