I have done a factory reset on my Veralite & now cannot find her on my PC.
I have tried using my IP Scanner [Angry IP Scanner] with a Network cable from PC to Veralite. Since this pings all IP’s in a range I put in, I tried using the 192.168.81.100 to 192.168.81.254 but without success.
I have tried with my Crossover network cable - again no luck.
Vera’s network light is just flashing fast/flickering.
I have not listed all my searches, but how can I find her IP address to enable me to re-set her up?
I need to manually change her network settings as she is on a local network which uses 10.0.0.## range.
Fortunately, I have a screen dump of the Net & WiFi screen to enable me to re-set these once I can see her on my PC, but currently I can’t locate her.
Why did you start at 100? Vera has a statically set address at 192.168.81.1, you’ll need your laptop to be set on the same 192.168.81.x network.
You could also look at the DHCP leases on your router.
If you use an ip scanner that shows manufacturer names, it is listed under Sercomm. I use an app on my android phone called Fing, not sure what to use on pc
