Firmware Update Request & Announcements
Hello everyone,
We are introducing a dedicated space for requesting manual firmware updates to ensure a clear and organized process while our engineers continue working on the new firmware update UI.
How It Works
:white_check_mark: If you’d like to request a firmware update for your controller, simply reply to this thread with “Firmware update”.
:white_check_mark: Once the update has been applied, our team will react with a like to confirm it’s done.
:white_check_mark: We will also use this thread to announce new firmware updates, so you can decide whether you want to request an update or not.
This approach helps us keep things transparent and user-controlled, ensuring that firmware updates are applied only with your consent.
Let us know if you have any thoughts or suggestions!
Firmware update
Firmware update
Firmware update
Thanks, it’s on the current version now.
Firmware Update
Firmware Update.
And two suggestions:
Why not disable the auto updates on all controllers and let the users who want the auto update enable it and just push the updates out to those users?
Add the firmware version in this thread that you will be updated to.
Linux Firmware v2.0.77.3053.1 [production-194]
Firmware update
Firmware update
Firmware update
Firmware Update
Linux Firmware v2.0.78.3067.3
Firmware update
Firmware update
Linux Firmware v2.0.78.3067.6
Firmware update
Ezlo Linux Firmware v2.0.78.3067.7
Firmware Update
