Linux Firmware v2.0.77.3053.1 [production-194] for Ezlo Plus, Ezlo Secure
New
Networking:
  • Multi-step network configuration: multiple commands related to network settings passed as a single command.
  • Support for output for the full version of the Wi-Fi network scanner was added.
Scenes:
  • Action forwardNotifications:
    • Indicates whether firmware supports new alert path;
    • hub metadata passed along with the request, such as hub type, battery state. Available to use from templates.
Sensor Groups:
  • Device groups of persistent policies are marked as persistent objects;
  • CMS signal delay for armed+tripped events is calculated using entry delay and abort window according to a sensor group configuration.
Security System
  • Alarmed state broadcasts: entry delay from the sensor group is used.
  • Alarmed state phase “main” indication introduced.
Hybrid Notifications:
  • The first version supports the hybrid notifications alert path fully.
Fixes & Improvements
Scenes:
  • isBatteryState repeated scene runs fixed;
  • isBatteryLevel was not triggering scene execution when a condition is met.
Hybrid notifications:
  • forwardNotifications action:
    • Device fields were not accessible for template builder: device name and others;
    • A controller serial number template substitution data was added.
RF Team:
  • Z-Wave addon reboot mechanism adjusted;
  • Z-Wave ELECTRONIC LOCK LS-8076 device full support added.
Thank you for your continued support, and please let us know if you encounter any issues or have feedback!
Release notes link:
https://updates.ezlo.com/#note2261
