Including a FGR-223 device creates 3 devices of which the first two respond and the 3rd is a ghost. 1st device gets the name given with include. 2nd and 3rd get “_window covering” and “_window covering 1”.
So this device does not include succesful.
I will open a support case seperately.
Running latest firmware.
Let’s see if vera can make it’s promise true to support all zwave devises in the market. This is a mainstream device.
I have actually tried both ways: Adding it as a FGR-222 (Roller Shutter 2) device and a generic z-wave device. Both ways ended up in getting three devices installed.
What makes the picture even worse is that I do not get a status, whether the shutter is closed or open resp. the devices show contradictory status.
Hi everyone,
I’m facing the same issues: Ghost devices, and the slider on mobile app does not position the shutter.
Does anyone have a solution?
Thank you a lot
I have had problems like these before with a variety of devices but not recently. It’s interesting. I have not seen it in quite some time but I also have not included too many devices recently. I would guess this happens when the engine sees command classes which it either sees as redundant or does not recognize but why is a mystery.
For vera support it is as well. “I have removed the ghost devices” is the standard response 2 or 3 times a month for me… for the officially supported aeotec 6in1 motion sensor (fw1.13) now level 3 support is lookin into. But to be honest I dont have any hopes left.
That could be possible. But since the original device ids of the master also change every now and then and given the amount of ghosts (I am at device # 1300 (!) currently) this is not a solution but just playing with symptoms.
You are right. What kind of sulution is that!? I can imagine having around 1300 devices of which god may know how many ghosts that all need some sort of processing or handling time will do with my vera.
I am more disappointed in this product every time I open this forum…
