@sunqan Could you pls tell me what you changed exactly?
In the advanced settings of the device there is a field ManufacturerInfo in the variables tab. I copied the info from a working FGT-001 to the one I had problems with, and it started to work. You might have to restart Lua.
The current contents of that field is “271,4865,4096” (remove the quotes).
Pleas note that I did other changes prior to this, none of them helped. I am not 100% sure that just changing the Manufacturer info is enough.
But please start with that.
I changed that and it helped. Thanks a lot!!!
