This shows a different version of the web ui than what you mentioned and that it should have been deployed on August 5th. Why the discrepancy?
Too difficult a question.
Is anyone actually paying attention at Ezlo anymore? It seems like things have slowed to a crawl with any Ezlo releases. Are all of the efforts focused on the “Upgraded Dashboard” I have not seen any real forward progress for anything Ezlo related.
have you seen the new AI based Dashboard?
when you logon, you should receive this and take you to the new dashboard.
and if you want something more powerful you can logon to https://property.ezlo.com/ and select any one of these dashboards based on your use case…this is more commercial than home use tbh…but here it is anyway.
based on “lens” you choose (eg: Lens being your use case), it generates a relevant dashboard to that lens (use case)…because how a HVAC contractor want to see all the IoT is different than how a Coffee shop chain wants to see theirs etc…
and these platforms/dashboards are all Hub/Controller agnostic, they will show you data from other Hubs as well (like home assistant etc)…
and even give you an ability to deploy your own docker image with the rule engine to run locally etc…(all agnostic)…
That’s great but when are the bugs in the Ezlo plus going to get fixed? And when will you be able to customize a mobile dashboard?
the above is PWA, which means it works on a mobile phone as well.
do you have tickets for the bugs you are talking about please?
What if I want to use the native app? There always seem to be browser compatibility issues. So if someone updates their browser where’s the guarantee it doesn’t break the interface?
Yes there are tickets open.
native apps will catch up as well at some stage…
if you have any browser compatibility issues, pls report them.
can u pls dm me the ticket IDs you have so that I can see whats happening
