We’ve released a new Beta update for Ezlo WEB UI – 1.3.2 with the following:
New Features:
- HUBs grouping including:
- Default Ezlo Main group which includes all user hubs in the account
- Ability to manage/control all devices included to all hubs in the account without switching between hubs
- Ability to manage scenes/rules without switching between hubs
Fixes:
- Selection of devices from the devices menu
- Login fixes
- Fixes in the EZLOgic flow.
- Other minor improvements on settings and device settings pages
Hubs grouping description:
At the first login, for users with 2 or more controllers, a default group called Ezlo Main will be created.
To view the current group and switch between groups, a drop-down list item has been added to the right, at the top of the screen, near the page profile.
To go to the group management page, click “Settings” in the drop-down list.
Group Settings Page
The settings page has 2 sections: a section for creating a new group (1) and a section for viewing and editing existing groups (2).
Important: the controller can only belong to 1 group. In order to create your own group of controllers that are in the Ezlo Main group, you must first exclude them from the group. To create a custom group, you need to specify the name of the group (1), select the controllers available from the list (2) and click the “Save” button (3)
Once created, the group will appear first in the list of available groups. To edit a group, click on the Edit icon (1) to delete - Delete (2).
When editing a group, it is possible to change the name (1), exclude existing controllers (2) or add new ones (3), to confirm the changes, press Save (4), to cancel - Cancel (5)
Devices page
Now here are the devices of all controllers in the group, you can view the devices of the controllers that are offline (1 - gray dot) and online (2-3 - green dot). Also, the names of unreachable or offline offline devices are gray (1, 2).
EZLOgic page
This is now a list of scenes for all controllers in the group. If the controller is offline, viewing and editing the scene is not available.
In order to create a scene, you must first select the desired controller in the upper left drop-down list (1) and then click on the create button (2).
The controller can only belong to 1 group.
It is not possible to create a group of 1 controller.
The default group Main Ezlo, when created, includes a maximum of 32 controllers.
When editing and/or creating custom groups, there is no limitation on the number of controllers in the group.
