melih
October 15, 2021, 6:27pm
#21
here is another capability called “between” where you can specify a “time period” between two “times”
melih
October 15, 2021, 6:51pm
#22
And nested group capability, with validation for each entry (green/red indicators)!
The time capability is fine but can you edit your scene? I can’t, if I save the scene and subsequently go to edit the date and time option pops up but with none of the settings behind it.
melih
October 16, 2021, 12:45pm
#24
I was able to edit it.
can you pls clear your browser cache and try again.
If still the same, can you pls send a screenshot of what you see. I want to see which settings don’t pop.
thanks
Using Chrome and Edge, both emptied the cache and still having the same issue.
after saving and selecting Edit:
will do some more testing later on.
melih
October 16, 2021, 3:57pm
#26
my bad.
I should have mentioned. There will be a new release on Monday that will enable all those greyed out fields.
You will have all these functionalities enabled on Monday’s release.
There are currently 8 different functionality under Date & Time
[image]
1-“Days of the Week”
[image]
This allows you to select any days of the week.
If, for example, you want an automation that only runs on Wed and Sun, then you can use this function.
2-Days of the Month
[image]
This allows you to select any days of the month.
If, for example, you want an automation that only runs on 7th, 20th and 27th days of each month, then you can use this function.
3-Weeks of the Month
[image]
T…
melih
October 16, 2021, 4:03pm
#27
on that release we will also release a better “Device Management” page
it will be the Beta 0.3.1 version
the current one is Beta 0.2.1.
