I have had the beta Atom 2 now for a few days. I was looking at controlling devices locally, but i see no way to connect to the Atom when the internet is down. I have disconnect my Broadband and then tried connect to Atom 2 via App, no luck.
Hello,
The hub operates without internet, but the app still require internet to authenticate.
The full offline support will come soon into the app too.
Kind Regards,
Adina
All Ezlo hubs after power up establishing connection to cloud and in parallel listening for requests to be connected locally and can handle both connections in parallel.
Hubs don’t have dependencies from internet. In case you don’t have internet you always have possibility to make local connection.
As Adina said, mobile teams are working on the full offline support and it will come soon.
Hi @mythtified,
Are you using IOS or Android app ?
If IOS, app will find your Atom automatically in the local network and will be connected in local mode.
Yes my phone is connected to the same WIFI network as the Atom.
I also had 4G Mobile data turned on my phone. I have now turned this off, launched the Vera mobile app again and connected to the Atom and it still says “Relay Connected”
When I first open the Vera mobile app each time it lists all my controllers, I have four of them.
This may be related to the problem getting the token for the Plus. Initially none of my hub would not connect locally either. Now they mostly do, but not always. No idea why as any of my tools connecting local always work.
You could try to remove the plus from your account and add it again.
The Ezlo team could not see anything missing for your set-up. It may have been a timing thing they think, but that implies you should be able to get a token for the plus now. However, now you have unauthenticated working there is no real need I suppose.
