This started with the last one or two updates. Don’t know which. There’s a Javascript error when displaying devices in a particular room. All other rooms seem to display ok.
The javascript error appears to be
TypeError: _devicetypesDB[elems[0]][device.device_type][json] is undefined J_ALTUI_multibox.js:106:2
I can display devices in a different room first, and the devices all look and work ok. This is the console output after clicking the room with the problem. And the image I attached shows what it looks like. It may just be coincidence that ALTUI is in this room. I have a second Vera3 with altui in a room and it works fine.
2015-09-29T19:56:53.907Z: ALTUI v0.82:Icon for device altuiid:0-178 device.type:urn:schemas-upnp-org:device:altui:1 J_ALTUI_utils.js:311:4
2015-09-29T19:56:53.907Z: ALTUI v0.82:Icon for device id:0-178 string from json:http://code.mios.com/trac/mios_alternate_ui/export/12/iconALTUI.png J_ALTUI_utils.js:311:4
2015-09-29T19:56:53.907Z: ALTUI v0.82:Icon for device id:0-178 string after correction:http://code.mios.com/trac/mios_alternate_ui/export/12/iconALTUI.png J_ALTUI_utils.js:311:4
2015-09-29T19:56:53.907Z: ALTUI v0.82:Icon for device id:0-178 IconPath:http://code.mios.com/trac/mios_alternate_ui/export/12/iconALTUI.png J_ALTUI_utils.js:311:4
Any ideas?
Thanks!! --David
