I have quite a few relays used to actuate different equipment. In Vera (Vera Plus UI7) these show up as lightbulbs, and are toggled by the “Turn All Lights On/Off” switch.
I understand that I can change the device type and icon.
However it is not clear to me excatly what I need to change and how.
Can someone explain what the advanced params really do?
device_type
device_file
device_json
Say I want my relay to show as a valve or a switch instead of a light bulb. What would I need to change, and would changing it have any other possibly unwanted effects?
[quote=“chrlod, post:1, topic:197484”]I have quite a few relays used to actuate different equipment. In Vera (Vera Plus UI7) these show up as lightbulbs, and are toggled by the “Turn All Lights On/Off” switch.
device_type
device_file
device_json
Say I want my relay to show as a valve or a switch instead of a light bulb. What would I need to change, and would changing it have any other possibly unwanted effects?[/quote]
If what you are trying to change is the icon, it is stored in the device json.
If you open up the json you will find if the icon has a subcategory dependency. You can extensively modify the json to use your own icons. I would recommend to make a copy of the current json file for your device, rename it, and change the icon file names in it then upload the new json and use the renamed json in your device.
I am trying to do the same thing.
I have a light that is showing up as a wall plug.
I change the Category number from 3 to 2 and Subcategory from 3 to 0
I copied this from another device that shows a light bulb. Doing this did change the icon from a wall plug to a light bulb but it only stays like that for about 1 min before it changes its self back to a wall plug. How do I open or change the json file ?
Changing device categories and sub categories is pretty straight forward but is anyone able to advise how I can stop UI7 from constantly re-configuring the device and changing the settings after they are changed?
Once I change a device sub-category to what I want the device works perfectly but overnight Vera will reconfigure the device and change it back… it?s so frustrating .
When you get into the device page and choose your device, click on settings and change the “automatically configure” option to no. save the changes. This should stop your device from automatically configure.
Not sure, I have 2 dozens of devices which I manually configured and they have never changed back. It sounds to me like the vera did not consider the device as having completed configuration and is therefore trying to configure it again so in fact you are dealing with a new child device. What kind of device is it?
AFAIK some devices (Fibaro FGS, for example) have an hardcoded category ID and you cannot change it.
I recently contacted support for a similar problem, since they changed the category for the doorbell from category 3, subcategory 6 to a different category ID.
they confirmed I cannot change my Fibaro’s category ID from 3 to something else. If I do, I’ll have it reconfigured at next luup reload.
I can confirm issues witch changing category of some Fibaro devices.
For example I’ve never managed to change category of their RGBW controller, it always go back.
Aeotec is also fussy - some devices allow changes in categories, but not big ones (as far as I remember I was able to change subcategory only and only few were accepted, but I would need to re-check it to confirm).
Anyway, sometimes it works strange. For example I successfully changed device category to Water Valve for some Qubino relay switch, but I see proper icon only under mobile App and only on Windows Phone. on Android and web UI, it is still presented as a lightbulb.
that’s because icon is hard coded in every app. so they need to keep all the logic in sync and sometimes they’re not. that’s the same problem with custom device not showing data on some apps (iOS) and working on other (Windows, Web) and viceversa.
One changes the categories in Params section of the device under Advance.
Then go to the Commands folder (4th folder)
Click on “Configure node right now” to save your changes.
The changes may go away during the next reboot.
Some devices will not let you change the Category, some will not.
I’ve been able to get devices off the “Turn All On” list but just changing the subcategory to 8.
