Device has always been able to pair with the Vera. Problem comes after pairing is complete.
Iāve tried factory resetting the device, and then re-pairing it with the Hub.
The Device always pairs with the hub without an issue. The Vera detects the new device and adds it (It sees it as a generic device).
The problem is that after pairing the device just stays in āWaiting for wakeup to configure deviceā, OR 'Please Wait! Getting the Manufacturerā.
The device can be manually woken up by pressing the button on the device for 2 seconds. When this is done, the LED on the device flashes, but still no change on the Vera itself. Itās like the Vera doesnāt see it after it is paired.
Not to dig up a corpse or anything, but I think Iām missing something here and this appears to be the most recent thread on this deviceā¦ is the GE Jasco 14287 Fan Switch actually properly supported? I can get add mine as a node but it just shows up as a regular in wall light dimmer. Running the latest VeraPlus firmware.
