Can't delete unsupported generic z wave devices
I tried to set up a Zooz double plug (ZEN25) only to discover it isn’t supported yet on Ezlo Secure. They are working on it.
I tried to set it up as a generic Z Wave device but it didn’t work (app and plug out of sync, etc.).
My problem now is I have two plug devices which I cannot remove. I tried unpairing, purging and delete but the devices remain.
Any ideas?
You might have to use this script to delete them
Thank you but I seem to be one of the unlucky ones that doesn’t have a password on the back of my ezlo secure.
None at all ?
I think the root password is the WIFI password on the sticker
That worked! Thank you again.
You will have to use the Online API Tool to discover the ID number of the device(s) you want to delete. You know how to do that ?
No. I haven’t had to. I’m on the api site.
Hub.devices.list hit the send button
In the Response find the device in question and make a note of the _id
Then use that with the script command to delete that device
That worked just great. Thank you.
