Can I transfer a Vera secure to an ezlo?
I would like to re-open this.
Can someone update if it is possible to migrate the configuration from Vera to Ezlo?
I am referring more to the Z-Wave configuration as exclude / include is very complicated since most of my modules are installed inside the walls.
Is this possible via backup and restore?
Thanks,
Nir
Hello @nirgal,
Our team is working on a tool to migrate the Vera devices to eZLO, but we do not have an ETA yet.
You will be able to use your new eZLO controller in parallel with your Vera, and start migrating your devices manually and with time.
We apologize for the inconvenience.
The working on it statement is something I got also two years ago - just go back in this thread.
I also found this thread:
https://community.ezlo.com/t/re-issue-adding-ezlo-secure-as-a-secondary-to-vera-secure/219800?u=nirgal
In that case I was told your team can do this for me - is this still the case?
Thanks,
Nir Gal
Hello @nirgal,
Correct, but it apply only to the Z-Wave devices, the scenes and the other settings must be set manually again.
Let us know if we may proceed and we will create a support ticket for you and apply the process.
Hello,
I would like, I guess I will get an email with the case ?
Thanks,
Nir Gal
Hello @nirgal
Correct. Check your inbox, or spam folder, please.
I didn’t receive any email, checked my SPAM as well.
Can you sent another message via the case system?
We can also use my work email ( which I also use to open support tickets ):
nirgal@****.com
Thanks,
Nir Gal
Hello,
Wanted to check if the migration process was fix/improved ?
Thanks,
Nir Gal
Hello @nirgal,
We have a new firmware version available! You can give it a try by following the instructions posted here: Updates for EZLogic 1.61.1 - 2.0.1
Let us know how it works for you!
Vera to Ezlo Migration
So long waited migration feature is now available publicly. You can access the tool under ā€œSettingsā€ main menu item.
The migration tool allows you to select a previously created backup from a Vera controller and apply this backup to an Ezlo Controller.
You can get the backup of Vera Controller(Vera Edge/Plus/Secure) from the backup menu under ā€œSettingsā€ main menu item.
And then select your controller to migrate devices to :
!!! Please Pay Attention !!!
This procedure will only transfer Z-Wave devices
the Vera Edge/Plus/Secure you are transferring from must be powered off
The Ezlo Controller you migrate to will lose all existing z-wave devices.
The z-wave home ID will be the same as the one in Vera controller. So if you turn on your Vera controller again, devices will be controllable by both of the controllers at the same time.
We will be improving the tool in upcoming releases.
Hello,
The version you pointed is from October 23, so I am quite sure I tried it and it failed!
You can see this thread:
Did anything change?
No new version since then?
Thanks,
Nir Gal
Did you ever get it to work? I am having the same problem.
Not really, each time something else is not working, for now I stayed with Vera.
Maybe some day this suppose to be easy process will work
