Beta feedback Ezlo Plus
These Zigbee 3.0 RGB bulbs pair to the Ezlo Plus but I cannot change the colours.
I was able to change the bulb from a cool white to a more warm white however.
But RGB doesn’t work.
I can’t even turn this bulb off with the Vera mobile app, so not good.
I can dim the lamp down using the slider, but the buggy Vera app says its at 0% and off, when it’s not and the lamp is on.
I can also brighten the lamp using the slider, and again the buggy Vera app doesn’t update or refresh the device Status properly and still says its 0% and off, when its not off its on.
https://www.lidl.co.uk/en/p/smart-home/livarno-lux-smart-colour-change-light-bulb/p37573
Then in the Vera app selected to Delete the device then unpair and then clicking the Delete Device button on that screen and nothing happens.
So came out of that screen, selected delete device again but this time did not select unpair and just selected delete from this dialogue box instead.
I then used the Vera app to pair the bulb to my Vera Plus but as expected it doesn’t work. It did pair the bulb but the device item for it in the app just says “Generic Zigbee Device” There is no on / off button or dimmer or any controls of any kind. So you cannot do anything with the bulb.
Both Vera hub and more worrying Ezlo hub have failed to work with a simple Zigbee 3.0 RGB bulb.
I’ll pair it to my Hue Bridge next.
Pairs and works fully in the Philips Hue app, I can now change RGB colours OK.
For a cheap £9.99 bulb from a super market its OK, just not if you plan to use it with an Ezlo hub.
Here are the details written on the bulb itself.
Paul Hibbert recently did a video about these cheap Lidl Zigbee 3.0 smart home products.
Note - These RGB bulbs do not appear to work for the ColorLoop effect on the Hue Bridge.
