If you have Insteon working on yours you can use an Insteon IO-linc. The momentary relay side to open/close the door and the sensor side wired to a basic magnetic door sensor that I attached to the garage door track.
I would call Vera support to make sure if the Linear Z-Wave Garage controller works with Vera. Last time I checked, I was told that they are still working on supporting it, and even when it is done, it will require UI7.
So I bought mimolite instead, which is very similar.
I just installed the new Telguard GDC1 (soon to be officially released) and am happy to say it works like a charm with Vera UI5. From Inclusion to function only took 30 minutes and a screwdriver. I’d say this if definitely a contender for the title.
This is ideal solution, and I bought one, but doesn’t work with Vera yet. Device includes and is detected as garage door controller but it won’t do anything. I logged a ticket with Vera but nothing so far.
[quote=“BOFH”]I just installed the new Telguard GDC1 (soon to be officially released) and am happy to say it works like a charm with Vera UI5. From Inclusion to function only took 30 minutes and a screwdriver. I’d say this if definitely a contender for the title.[/quote]I don’t like how it’s implemented as a standard switch
. Not very clean imo and no way to get status of door out of it…
Actually the status can be easily determined by the ‘lightbulb’ icon. If it’s ‘lit’, then the door is open. Maybe not 100% ‘clean’ but it works out of the box which is more than I can say for some of the other solutions. And since Vera’s devices are controlled by XML and JSON files, it should be possible to customize the icon and buttons.
[quote=“libby2cm, post:8, topic:183459”][quote=“BOFH”]I just installed the new Telguard GDC1 (soon to be officially released) and am happy to say it works like a charm with Vera UI5. From Inclusion to function only took 30 minutes and a screwdriver. I’d say this if definitely a contender for the title.[/quote]I don’t like how it’s implemented as a standard switch
Shawn posted a fix for UI7 to change it into a garage door and open/closed text. It’s a combo of the device XML and JSON files. Doesn’t work for UI5 though…
I use the honeywell total connect home mobile app to control my garage. It lets me control the complete garage i.e lock doors and do stuff just at the click of a button.
