[quote=“a-lurker, post:59, topic:188330”]Hi amg0
A couple of queries: using AltUI v0.77.708: on some of my scenes the last run date is not shown - not sure why? Here is the raw json - the first displays the time; the second doesn’t.
[code][{“name”:“Sunset trigger”,“enabled”:1,“template”:“1”,“device”:140,“arguments”:[{“id”:“1”,“value”:“0”}],“lua”:“”,“last_run”:1443168690}]
[{“device”:148,“template”:1,“name”:“AUTO_GENERATED”,“arguments”:[{“id”:1,“value”:2}],“autogen”:1,“enabled”:“1”,“last_run”:1443188349}]
[/code]
Same code made pretty and reordered:
"device": 140,
"name": "Sunset trigger",
"template": "1",
"enabled": 1,
"arguments": [
"id": "1",
"value": "0"
"lua": "",
"last_run": 1443168690
"device": 148,
"name": "AUTO_GENERATED",
"template": 1,
"enabled": "1",
"arguments": [
"id": 1,
"value": 2
"autogen": 1,
"last_run": 1443188349
Only differences appear to be the types in “arguments”, the variable “autogen” and the variable “Lua”
I also have a Aeon minimote scene controller and all of the setup tabs in the control tab are missing in AltUI except the “Control” tab. What do you need to figure that one out? All the missing tabs use this style of json:
"Label": {
"lang_tag": "ui7_settings",
"text": "Settings"
"Position": "1",
"TabType": "javascript",
"ScriptName": "shared.js",
"Function": "simple_device"
[/quote]
regarding the scene, these json are not the scene json, they are the device event trigger json, so it is not related , we need to look at the scene json. you can get it this way
do to Misc / debug and choose javascript command and type
MultiBox.getScenesSync()
we should see lastrun attribute but at the scene object level.
also check if this lastrun is also displayed in UI5 or UI7
regarding the minimote, can you give me the json file that it uses ? ALTUI does not display javascript tabs which are with “ScriptName”: “shared.js”
these are UI5/7 and it is impossible to display them unless I reemplement the complete api of UI5 UI7 which is not really possible nore desirable
there could be other way, lets first see the json and tell me the kind of UI you are missing, maybe we can implement some custom panels
